Generation V Internal Engine 2013-20xx LT1
Can a GEN V be cam swapped without dropping the pan?
Old Nov 27, 2023 | 09:59 PM
Scarebird's Avatar
Default Can a GEN V be cam swapped without dropping the pan?
I need to swap a cam in car and realise I cannot get the oil pump out without dropping the pan. Needless to say I have no desire to do this!
If the crank remains in the same position can the new cam be installed at the same rotation position as the old?
This pic is from a Moter Trend article
Old Nov 28, 2023 | 06:38 AM
B_the_Builder's Avatar
Yes I didn't drop mine l86 gen v. I'm no professional but it can be done without dropping the pan
check this out!
Old Nov 28, 2023 | 11:30 PM
Scarebird's Avatar
I did check out the video - thank you, and learned a couple of things.
Unfortunately, the cam gear would not drop down far enough to disengage the chain - it hits the tensioner. Another 0.200" and would have been golden.
I will need to pull the motor as this engine must not leak at all where it is going and sealing it in the car is a shaky go. While it is out I will paint it Pontiac Blue among other things..
