Generation V Internal Engine 2013-20xx LT1
do I need to rebalance before assembling the engine ?
Old Nov 29, 2023 | 10:56 AM
DLYLTX's Avatar
Question do I need to rebalance before assembling the engine ?
good morning guys
I hope I can get help in here my car is Camaro 2016 SS Engine: short block lt1 gen V
I spun a bearing , I have purchased new crankshaft from GM (stock) to avoid waiting
and I have used set of pistons and rod from zo6 2020 LT4
Do I need to rebalance them before installing?
thank you
InstaLYLTX
Old Nov 29, 2023 | 07:45 PM
The LT4’s forged pistons and trick steel rods are going to change the balance of the assembly. If it were mine, I’d balance it, but I balance everything. Balancing will help cancel out harmonics that will rob power.
Old Dec 5, 2023 | 09:01 AM
kinglt-1's Avatar
Yes you will want to balance it.
