Generation V Internal Engine 2013-20xx LT1
BTR Spring Kit Install L83 Heads
Old Jun 1, 2024 | 12:56 AM
SHINER's Avatar
Default BTR Spring Kit Install L83 Heads
I’m in the process of swapping cams and I’m swapping the springs on these heads.
It came with
-Springs
-Shims
-Locators
-Retainers and Locks
I called BTR and they stated that each guide needs 1 shim and 1 locator. Is this everyone else’s experience?
I always thought shims were to achieve a certain spring pressure. I am currently installing a shim before slipping the locator on. Is good?
Old Jun 1, 2024 | 08:15 AM
SHINER's Avatar
Anyone
Old Jun 2, 2024 | 09:50 AM
01CamaroSSTx's Avatar
I would check to see if your getting 1.78" from the spring locater to the retainer with the shim installed and if so then you're good to go. Also take a feeler gauge and check valve spring coil clearance between the inner and outer valve springs when at full lift. You're looking for a minimum of 0.060".
Old Jun 8, 2024 | 10:47 AM
LilJayV10's Avatar
Have you checked the spring height to see what it is?
