Holden Performance Australian LS1 Powered Vehicles
head bolt torque settings for ls1
Old Aug 14, 2017 | 03:01 AM
tyrone davies's Avatar
Default head bolt torque settings for ls1
hey guys my bro has an ls1wanting to use a mls gasket we are wondering if the bolt torque settings are different from stock settings
Old Jan 31, 2018 | 08:33 PM
01CamaroSSTx's Avatar
Just to be clear you can't use the stock head bolts again as they are TTY bolts and once used they are are done and you will have to buy a new set. If using the ARP head bolts they can be used again.
The TTY or stock bolts have a poundage torque followed by an angle torque as where the ARP bolts are a 30-60-90 lb torque sequence. Running a MLS head gasket does not require a change in the torque values. Hope this helps!
