Is there a schedule for the event?
Also, I'm still trying to figure out how I can drive the car 24 hours roundtrip and bring my competition tires without owning a hitch or trailer. If I assume I find a way to haul the tires, and register with comp tires, then worst comes to worst and I have to use street tires, will I be allowed to switch my registration to street tires?
Also there are some unique events that are not drag race but will use the drag strip. The Speed Stop Challange is a example.
Yes once you tech in on Friday you are good for the weekend Also tech will close at noon onSaturday so be sure to be there before noon.
Another cool deal is that all cars that must qualify for a heads up class will be allowed test passes between the official qualifying sessions. So if your frustrated and can't get your junk figured out get it into the lanes during the test sessions. Runs during those time will not be counted towards qualifying.
Robin
How stock does the interior need to remain? If I could legally remove the front passenger seat, I might be able to lay the front tire down flat on the floorboard, which would also give me better vision out the passenger window.
I already did re-review the currently posted rules and was looking for clarification. Autox/Speed stop rules regarding vehicle preparation are fairly vague:
8.Participants must use DOT approved tires. Tires will be required to pass a technical inspection at the track. Street tires are defined as any treaded, non-competition street tire with a 200 tread wear rating or higher. Comp tires are defined as any treaded or grooved DOT tires with a tread wear rating less than 200, or “R” compound track tires. No slicks, modified or shaved tires will be allowed and street tires must have a minimum 5/32-tread depth.
9.Competitors must use a single set of tires for the entire event, no tire changing between events will be allowed. Tires will be marked during tech. Tire changes will be allowed in the event of a catastrophic failure, but replacements must be of the same manufacturer and model as those approved during tech inspection.
11.Participating cars must pass a basic safety inspection that will include but may not be limited to the following:
a.Functional seatbelts.
b.Proper brake pedal pressure and travel.
c.Sufficient throttle return spring and secured battery.
d.All lug nuts in place and tight.
e.Hubcaps/clip-on center caps are to be removed.
f.All loose items must be removed from vehicle. (Floor mats, things hanging from rearview mirror, cassettes, CDs, and glove box, console, trunk items.)
Robin says to be sure we arrive before noon Saturday... does that mean we don't need to be there for every autocross event? I don't understand how we determine when we race when there are multiple time windows over the weekend.
I will forward this to Jimi Day for a response.
Thanks
Robin
To me, that means as long as the exterior is basically stock, the interior doesn't matter so long as you have functioning seat belt for every installed seat. Whatever weight I can easily remove before the event and re-install later I'd like to chase... extra seats, carpet, rear seat belts, etc. With the rules subject to change at any time prior to the event, I don't want to arrive only to be told I can't compete because I removed the wrong items.
We will not allow a switch from comp tires to street tires after registration. It is possible to register for both classes for an additional fee.
AX and SS competitors must make at least three runs on each to qualify for the Grand Champion award. Aside from that, there is no other requirements for AX and SS. The drag race times dictate participation in all other events, so plan accordingly. Don't be in line or on the AX course when your drag class is called.
This is a first year event and we will be as flexible as possible with all competitors providing it doesn't give a competitive advantage to anyone. In exchange, we appreciate your patience with our team!
