Roll Call!!!
It will most likely rain part of the time.
That's racing at a 3 day event.
could probably be a bigger deal than this:
But either one could be an issue so you should probably get a harness belt and (legally) add some weight to the car (maybe run bigger front wheels with lower pressure?) to get it closer to 134mph.
This look okay? They have the same ones in stock at my local speed shop. Where do the lap belts mount to? The same place the stock seat belt latches to and the anchor point for the lap belt? Where does the crotch strap mount to?
Will a 3/8's grade 8 bolt go through the stock hole for the lap belt?
