New Ls1 Ls6 GM Engine
Old Nov 10, 2008 | 12:36 PM
Ls6JP's Avatar
Default New Ls1 Ls6 GM Engine
I've decoded to sell my New Ls1 Aluminum Motor Project I was going to build for a Gen 1 Camaro Swap. I'm new to this forum. How do I post in Classified Section?
Brand New Ls1 Ls6 GM Motor. All New Never Assembled.
New GM Aluminum Block #12561168
New GM Crankshaft #12552216
New GM Powdered Metal Rods w/ ARP Bolts
New GM Pistons #88984245
New GM Head Gaskets #12498543
New Lingenfelter GT1 Roller Cam & Lifters
New Matching Valve Springs
New Valves
New Ls6 Push Rods
New Ls6 Rockers
New GM Rocker Arm Stands
New GM Oil Pump #12563964
New GM Rear Sump Oil Pan #12558762
New GM Oil Pump Pick up
New GM Windage Tray
New GM PVC Tube Assy
New GM PVC Ls6 Plug
New GM Knock Sensors
New GM Valley Cover
New GM Timing Cover & Rear Cam Cover
New GM Center Bolt Valve Covers
Mew GM Mass Air Flow Sensor #25318411
New GM Ls6 Intake w/ Throttle Body (Drive By), Fuel Rails & Injectors.
New GM Ls6 Coil Packs
Nice Used GM Ls6 Flywheel
Nice Used GM Aluminum Ls1 Ws6 Heads
Make resonable Offer! Will not seperate, all or nothing!!
Call me if interested @ 614-204-6723 or email me at pennlp@aol.com
Old Nov 10, 2008 | 12:52 PM
ss69's Avatar
You won't be able to post it in the for sale section until you've been here 6 months or you have something like 50 or 100 posts.
Old Nov 10, 2008 | 01:10 PM
NeedaV8foundation's Avatar
here ya go...
https://ls1tech.com/forums/lsx-parts...-3-4-08-a.html
