Hello from Nothern VA
Old Jul 20, 2010 | 03:31 PM
Billws6's Avatar
Default Hello from Nothern VA
Hi my name is Bill. This is my first time posting in LS1 tech. I was a moderator at firebirdV6.com a long time ago. I have been a f-body owner since 1986 when I bought my first 1986 Firebird SE.
Currently I own three F-Bodies.
I have a 2000 WS6 with Lingenfelter 427 LS6
I have a 1997 Firebird
My wife has a 1998 Formula
My WS6 has run a 11.220@123 on motor spinning out of the hole with a 1.866 60 foot on MT Drag radials. The car weighs 3800-3900 with me in it. I’m a big boy.
The build in the WS6 is:
POWER PLANT:
Custom 7.0 L Lingenfelter 427 LS6
Darton modular sleeve assemblies
ARP 8740 premium grade head studs
Lingenfelter CNC ported and polished 243 casting LS6 cylinder heads
2.100” Stainless steel intake valves
1.57" Stainless steel exhaust valves
Three angle valve job, correct setting of spring tensions
Comp Cams valve springs and titanium retainers, 10 degree locks and valve stem seals
Custom designed G-11 LPE hydraulic roller camshaft
215/231 Duration - 631 Lift intake - 644 Exhaust - 118 Centerline
Custom JE forged aluminum pistons
Custom Callies 4340 forged steel crankshaft - 4.00" stroke
Manley fully machined 4340 forged steel connecting rods - 6.125" long
Comp Cams Chromemoly 5/16 7.400 Pushrods
Computer balanced rotating assembly
Hi Volume oil pump
SFI Rated Fluid Dampener
50 lb high flow fuel injectors
NGK TR55 Iridium IX Spark Plugs
Magnecor 8.5mm performance wires
Heat Resistant Wire Socks
Blueprinting of the engine
Lingenfelter testing and tuning
LS1 Edit and AutoTap Software
INTAKE & COOLING SYSYEM:
FAST Technology LSX 90 MM intake manifold
90 MM throttle body
Low restriction Air Whisper Lid and K&N air filter
Be Cool Aluminum Crossflow radiator with transmission cooler
Unrestricted Ram Air mod
EGR modification
160 degree thermostat
Throttle body by-pass
SLP Manual Fan Switch
EXHAUST SYSYEM:
KOOKS Long Tube Race Stepped Headers (1 3/4 to 1 7/8 to 3 inch outlet)
KOOKS High Flow Catalytic Converters
Corsa stainless steel 3 inch cat-back exhaust system
TRANSMISSION:
Rossler Performance Terminator 3 - Heavy Duty Transmission with
4L65 hardened shaft Modified Lube Circuit, Modified pump to HP specs. Installed high RPM pump slide spring, Modified input drum (prevents input drum breakage at spline area), Installed HP 3-4 9/clutch pack, Installed Ross/lock™ ¾ clutch kit (20% more surface area than normal HP 9 clutch kits), HP reinforced mounting lugs 2nd gear, Band 18% (more holding power than normal HP type bands), Modified bearing kit-ring gear support hub (eliminates brass washer wear), Installed Heavy Duty sun gear shell (prevents breakage at spline), Reprogrammed valve body Ross/Lock ™, Installed Corvette type 2nd gear Servo kit, 4th gear billet servo kit, 2nd Gen. Sprag kit, 13 vain pump rotor, and Turbulator ™ steels where applicable
Yank Super Sport 3200 Stall Converter
245mm, Stall speed 3200 Posi Lock-Up Clutch w/Kevlar Linings, lightweight billet cover
TCI - Dual bolt pattern, 168 tooth (1500 HP) SFI rated Flex plate
Hughes Performance cast aluminum deep transmission pan
DRIVE TRAIN:
Series 3 Moser 12 Bolt Rear with girdle and 33 spline axils
Eaton limited slip posi
Richmond 3.73 gears
Denny’s Nitrous Ready Drive Shaft w/1350 series transmission slip yoke and solid body U-joints
BMR Drive Shaft Safety Loop
SUSPENSION:
Spohn Adjustable Tubular Polyurethane Ended (Lower Control) Trailing Arms
Spohn Adjustable Tubular Polyurethane Ended Panhard Bar
Energy Suspension Polyurethane Transmission and Torque Arm mounts
Prothane Motion Control Polyurethane Motor mounts and bushings
Competition Engineering 3-way adjustable drag shocks (rear),
BMR adjustable Torque Arm
Kenny Brown Double Diamond Subframe connectors
BRAKE SYSTEM, TIRES & RIMS:
Front and Rear PowerSlot Rotors
Front and Rear Hawk Performance Brake Pads
Front & Rear Stainless Steel Brake Lines
Hurst Line Lock
Street Tires – Mickey Thompson ET Street Drag Radials 275/40/17 (26”x11.50” -17”)
Track Tires – Weld Draglites, Mickey Thompson 26/10.50/15 (ET Streets, rear)
Track Tires – Weld Draglites, Mickey Thompson 26/6.0/15 (ET Skinnies, front)
My Firebird V6 has run a 13.967@90.42 with a 1.776 60 ft. Remember, I’m still a big boy.
The build in the Firebird V6 is:
Performance modifications include a NOS 90HP nitrous kit #5175,
MSD 8.5mm wires
NGK TR6 spark plugs
MSD DIS-4 ignition
160° thermostat
SLP cold air induction system
Removed MAF throttle body screen
Random Technology 3" highflow cat
Edelbrock 3" in/dual out catback exhaust
9.5" Vigilante 2800 stall converter
TransGo shift kit
Perma-Cool transmission cooler,
ES Polyurethane transmission mount
1LE aluminum driveshaft,
G2 driveshaft safety loop,
Hotchkis strut tower brace, lower trailing arms, panhard bar, and subframe connectors. Firestone Firehawk 245/50ZR16 front tires
Nitto 245/50R16 drag radial rear tires.
Factory Y87 performance package and W68 appearance package
The wife’s Formula is totally stock and has not ran at the track
The first picture is of my WS6 running at Englishtown.
The second picture is of my 1997 Firebird V6
The Third picture is of my wife's Formula
The fourth picture is of my previous 1986 Firebird
The fifth picture is of my 1997 Firebird car show ready.
Sixth picture is the dyno pull Lingenfelter did on the car once the build was installed and completed
The seventh picture is of my V6 launching at MIR
The last picture is of my 2000 ready for a car show
Bill
Attached Thumbnails Hello from Nothern VA-my-2000-ws6.jpg   Hello from Nothern VA-my-97-firebird.jpg   Hello from Nothern VA-debs-formula.jpg   Hello from Nothern VA-1986_pontiac_firebird_se_1_cd_gallery.jpg   Hello from Nothern VA-car-side-shot-4.jpg
Hello from Nothern VA-427-dyno-results-rpm-.jpg   Hello from Nothern VA-phantmm-dragathon-launch.jpg   Hello from Nothern VA-bills-ws6.jpg
Old Jul 24, 2010 | 02:34 PM
Johns00Z28's Avatar
Cool cars! Where are you at in NOVA?
Old Jul 24, 2010 | 02:51 PM
Billws6's Avatar
I'm in the Sterling area.
Old Jul 25, 2010 | 02:01 PM
Glenn B's Avatar
Welcome to Tech
Great group of cars you have there!
Very nice.
--Glenn
Old Jul 26, 2010 | 11:30 PM
Billws6's Avatar
Thank you Glenn. It's nice to be here
Bill
11.220@123
Old Jul 27, 2010 | 02:37 AM
gyrene2003's Avatar
thats awesome man. thier is a pretty big NOVA car group for f-bodys i used to be part of, do a google search. I used to be part of them when i was in the corps at quantico in 04-06. They are the f-bodyhideout. thye do pretty cool **** for 9/11 called ride for pride its just a badass cruise! Sweet cars by the way man!
Old Jul 27, 2010 | 06:14 AM
Need_a_Camaro's Avatar
I'm not too far from NOVA, used to work in the Chantilly/Leesburg areas. Sweet car man.
Old Jul 27, 2010 | 07:16 AM
00T/AWS6's Avatar
Welcome the tech. Are you by chance the 427 that's friends with chris (raven)?? I was at chik-fil-a with him and he said a 427 bird was going to show up but i had to leave early Anyway i'm sure if your in sterling i'll see it out at chik-fil-a on fridays.
Also what gyrene2003, check out the f-bodyhideout. All the locals are on there and more meets on that site.
Old Jul 27, 2010 | 09:47 AM
Billws6's Avatar
Thank you all for your compliments and kind words.
00T/AWS6, Thanks for the heads up on F-Body Hideout. I'm already a member there. To answer your question, yes I am Chris (Raven's) good friend with the 427 and I do go to Chik-Fil-A on Friday nights when I can. I plan to be up there this Friday. You can't miss me im a very big boy (over 350 lbs).
Bill Spano
11.220@123
