How is it going?
Old Aug 13, 2011 | 06:02 PM
jmartinws6's Avatar
Default How is it going?
hey all my name is jesse from glen allen va. I have a 98 Trans Am.
The goods....
Factory LS1 Short Block w/~66k miles
PRC Stage 2.5 Ported 5.3L Heads with 2.02"/1.575" valves
Patriot Gold Dual Valve Springs .650" lift
Chromoly 7.4" Pushrods
Cam Motion Custom Grind Cam - 224/228 .595"/.578" 111LSA
GM LS2 Timing Chain
Newer Oil Pump
Flowtech Slip-on 1-3/4" Long Tube Headers Wrapped
Percy's Header Gaskets (yes this is the only gasket I will list..haha)
Custom 3" Y-pipe using Flowmaster 3"-4" Y collector reduced back to 3" with cutout
LS6 Intake Manifold
Factory Ported Throttle Body w/bumpstop, coolant bypass, knife edge, and half shaft mods
SLP Smooth Bellow
Ported MAF
SLP Air Lid
K&N Air Filter
Mike Morris Motorsports PCV Catch Can with new PCV valve and lines
GMPP Pontiac Valvecovers
Custom Relocated Coilpacks
Battery Relocated to the spare tire area
Fuse box relocated to where the air pump used to be
Air Pump removed
EGR removed
AC removed (still have components if you HAVE to have it)
Manual 2-speed Fan Switch
SLP Bilstein Road Racing Shocks
Sam Strano Performance 1.2 inch Lowering Springs
UMI Single Adjustable Poly/Rod Lower Control Arms
UMI Single Adjustable Poly/Rod Panhard Bar
UMI Performance Solid 35mm Front Sway Bar
UMI Tunnel Brace w/o DSL
Graphite Metallic C4 Grand Sport 17"x9.5" wheels with Kuhmo Ecsta XS 285/40-17's
Doors DeMolded and Debadged
Infinity Reference speakers in the front
Audiobahn speakers in the rear
Power Tower Pro 5.0 Short throw shifter w/ Lou's Short Stick
Motivative Performance Solid Motor Mounts
Polyurethane Transmission Mount
Old Aug 13, 2011 | 08:33 PM
AlamoTA's Avatar
Welcome to the forum. You'll find lot's of good info. Don't hesitate to contribute.
Old Aug 14, 2011 | 10:36 PM
z28241's Avatar
nice..u plan on runnin at the track? ..
Old Aug 15, 2011 | 03:47 PM
1Bad97WS-6's Avatar
Welcome to the site I'm from Fredericksburg,Va
