1st post...
Old Apr 24, 2013 | 09:56 AM
silvereagle1988's Avatar
Default 1st post...
Hi guys and gals... I just bought a Bright Red, 2002 Trans Am, WS6, Convertible, 6 speed, with Hurst Shifter. Just curious as to how many were made. Trans Am World lists 70 Bright Red Convertibles made.
I have found out the following including how many were made (One interesting note... Transamworld listed no QB6 Speedline 17” Whls, but my door tag has it listed.)
Any help finding units produced, build number or any other information would be appreciated.
Born Date: 05/02
Final Assembly: STE Therese, PQ
Sales Code: E
Dealer Number: 18-435 Units Produced
WS6 Convertible M6
FN3Q
Model Number: 2FS67
AAA 4-Way Manual Seat Adjuster
AK5 Restraint System, Frt Ctr, RR, Seat, Frt, Shldr
AQ9 Lux Reclining Seats 659
BBS Hurst Shifter 602
CAF HANDLING CHARGE GM ST THERESE TO AMERICAN SUNROOF (ASC) FOR UPFITTER CONVERSION (VTIMS)
C60 HVAC System, AC Frt Man Cntrls
DG7 Mirror O/S, LH & RH Rem Cont, Elec Defog, Chrome
DL5 Decal, Roadside Service Information
FE4 SP M SUSPENSION SYSTEM SPECIAL RIDE & HANDLING
GU6 3.42 Axle 714
C80 Po Traction 714
IL2 TRIM-INTERIOR DESIGN
J65 BRAKE SYSTEM, PWR, FRT & RR DISC
K43 EN M GENERATOR 102 AMP
LS1 5.7L GEN III V8 ENGINE
MM6 TRANSMISSION, MAN 6 SPD, BORG WARNER
MN6 Manual 6 714
NF7 MS M EMISSION SYSTEM FEDERAL, NLEV
NP5 LEATHER WRAPPED, STEERING WHEEL AND SHIFT ****
PBT IDENTIFICATION TEMPORARY HOOD FOR UPFITTER DELIVERY
PDC CONTROL SALES ITEM NO. 120
PDN CONTROL SALES ITEM NO. 131
QB6 Speedline 17” Whls 1
QFK P275/40R17-93W BW R/PE ST TL HW4
SLM STOCK ORDER, PROCESSING CODE
STE PLANT CODE ST THERESE, PQ, CANADA
T78 HEADLAMP CONTROL - DELETE
UB3 CLUSTER, INST, OIL, COOL TEMP, VOLTS, TRIP ODOM, TACH
U75 ANTENNA, POWER, RADIO
VM3 LABEL INFORMATION CONSUMER, CONTAINS BPR IMP STANDARD FOR FRT 5 MPH & RR 5 MPH
V12 COOLING SYSTEM, POWER STEERING, FLUID
V73 VEHICLE STATEMENT, USA/CANADA
WS6 Ram Air 714
WS9 MODEL CONVERSION, FORMULA
X20 Vert Monsoon w/CD 714
Y84 MERCHANDISED PKG, GTA, TRANS AM
1SA OPTION PACKAGE 01 714
191 TRIM COMBINATION LEATHER, BLACK
192 Black Leather
41T TOP COLOR, VINYL,BLACK
6BS LH M COMPONENT FRT LH COMPUTER SEL SUSP
7BS RH M COMPONENT FRT RH COMPUTER SEL SUSP
8TJ LH M COMPONENT RR LH COMPUTER SEL SUSP
81U Bright Red 70
9TJ RRH M COMPONENT RR RH COMPUTER SEL SUSP
BC/CC
U
8744
192 RM M TRIM COMBINATION LEATHER, EBONY
41T Black Top 342
Compnine lists the following:
Final Assembly: STE Therese, PQ Sales Code: E
Dealer Number: 18-435 WS6 Convertible M6
Vehicle:
2002
Build Date:
RPO Description
UB3 CLUSTER,INSTRUMENT(OIL,COOLANT TEMPERATURE,VOLTMETER,TACHOMETER,TRIP ODOMETER) GA(UB3)
UK3 ELECTRONIC SYSTEM,ACCESSORY CONTROL ELEK ACSRY CONT SYS(UK3)
U75 ANTENNA,POWER(CHROME) PWR ANT(U75)
VM3 LABEL INFORMATION CONSUMER, CONTAINS BPR IMP STANDARD FOR FRT 5 MPH & RR 5 MPH 5 MPH BUMPER INFO LABEL(VM3)
V12 COOLING SYSTEM,POWER STEERING FLUID P/S CLG SYS(V12)
V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73)
WS6 PERFORMANCE PACKAGE,SPECIAL(MERCHANDISING OPTION) SPECIAL PERFORMANCE PKG(WS6)
WS9 MODEL CONVERSION FORMULA(MERCHANDISING OPTION) FORMULA(WS9)
X2O ENTERTAINMENT SYSTEM OPTION M ENTERTAINMENT SYSTEM(X20)
Y84 TRANS AM GTA OPTION(MERCHANDISING OPTION) TRANS AM GTA(Y84)
1SA PACKAGE-OPTION 01 (1SA)
19I INTERIOR TRIM COLOR (19I)
192 TRIM COMBINATION,BLACK LEATHER (192)
41T VINYL TOP COLOR,BLACK (41T)
6BS SPRING COMPTR SELECT FRT LH SUSP(6BS)
7BS SPRING COMPTR SELECT FRT RH SUSP(7BS)
8TJ COMPONENT RR LH COMPUTER SEL SUSP (8TJ) SUSP(8TJ)
81U EXTERIOR COLOR,PRIMARY (81U)
9TJ COMPONENT RR RH COMPUTER SEL SUSP (9TJ) SUSP(9TJ)
AAA Unk.
AK5 RESTRAINT SYSTEM,FRONT SEAT,INFLATABLE,DRIVER AND PASSENGER DRIVER & PASS F/SEAT INFL RST SYS(AK5)
AQ9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,RECLINING RECL FRT BKT ST,LUXURY(AQ9)
BBS **** SHIFTER HURST HURST SHIFTER(BBS)
CAF HANDLING CHARGE - GM ST THERESE TO AMERICAN SUNROOF (ASC) FOR UPFITTER CONVERSION (VTIMS)
C60 AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60)
DG7 MIRROR,OUTSIDE,RH & LH REMOTE CONTROL,ELECTRIC(PAINTED) O/S ELEC R/CON PAINTED MIR(DG7)
DL5 DECAL ROADSIDE SERVICE INFORMATION ROADSIDE SERVICE INFO DECAL(DL5)
FE4 SUSPENSION SYSTEM SPECIAL RIDE & HANDLING SPECIAL SUSP(FE4)
FE9 FEDERAL EMISSION CERTIFICATION FED EMIS(FE9)
GU6 AXLE,REAR,3.42 RATIO 3.42R(GU6)
G80 AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80)
IL2 TRIM,INTERIOR DESIGN (IL2)
J65 BRAKE SYSTEM,POWER,FRONT AND REAR DISC 4-WHL DISC BRK(J65)
K43 GENERATOR 102 AMP 102 AMP(K43)
LS1 ENGINE GAS, 8 CYL, 5.7L, SFI, ALUMINUM ENGINE 5.7G(LS1)
MM6 TRANSMISSION MAN 6 SPD, BORG WARNER, 85MM, 1ST 2.66, 6TH 0.50, O/D 6-SPD M/TRANS(MM6)
MN6 TRANSMISSION,MANUAL 6-SPEED PROVISIONS(MERCHANDISING OPTION) 6-SPD M/TRANS PROVISIONS(MN6)
NF7 EMISSION SYSTEM FEDERAL, NLEV FEDERAL EMIS NLEV(NF7)
NP5 STEERING WHEEL,LEATHER WRAPPED LEATHER WRAPPED STRG WHL(NP5)
PBT TEMPORARY HOOD FOR UPFITTER DELIVERY
PDC CONTROL - SALES ITEM NO. 120
PDN CONTROL - SALES ITEM NO. 131
QB6 WHEEL 17 X 9, ALUMINUM, POLISHED SPEEDLINE WHEEL 17 X 9 SPEEDLINE ALUM WHEEL(QB6)
QFK TIRE ALL P275/40ZR17 93W BW R/PE ST TL HW4 TIRE(QFK)
SLM SALES PROCESSING - STOCK ORDERS
STE PLANT CODE- ST THERESE, PQ, GM OF CANADA ST THERESE,GM OF CANADA PLANT CODE(STE)
T78 HEADLAMPS CONTROL DELETE T78)
Attached Thumbnails 1st post...-img_7115a-4.jpg   1st post...-img_7179-4.jpg   1st post...-img_7181-4.jpg   1st post...-img_7077-4.jpg   1st post...-img_7168-10.jpg
Old Apr 24, 2013 | 12:02 PM
Bell Automotive Todd's Avatar
Closed ex-Sponsor Account
Welcome and sweet T/A you have there! She looks like she's in perfect shape. Totally jealous! Take good care of her!!
