New Guy With Efi Tuning Question
I have a quick question for the tuners on this forum. I have been learning on tuning Duramaxs and a lot of guys that have been around told me to get the road runner set up. So I bought a used one. Well comes to find out the Road Runner I bought will not work with my Duramax. So I want to make sure I know what this stuff will work on before I try to resell it. I know what the V2 is cause I already have one. Planned on reselling that also. Don't want someone to make the mistake I did. So what Years and Cars will this fit?
EFI Live FlashScan V2
Includes:
•Installation CD
•OBD2 (vehicle) cable
•PC (USB) cable
•1 available software license
•Warranty registration card
•Original box
Missing:
•1 (of 2) software license used
•Thermocouple connector missing
• Original box
Description
FlashScan V2 connects a laptop computer to a vehicle allowing you to diagnose faults, record data and tune your vehicle.
FlashScan V2 can simultaneously connect to other peripherals, such as wide band O2 controllers, thermocouple temperature sensors, analogue sensors and switches. Data may be recorded to FlashScan’s internal memory or to an optional SD memory card, the same type of memory card used in most popular digital cameras.
Roadrunner PCM
This is the 512k 12200411 PCM-based RoadRunner, which is a replacement PCM that allows realtime tuning for the LS1 PCMs. It works with the 1999-2002 F-Body LS1 setups as well as many of the 2000+ V8 trucks. Will work with either EFI Live or TunerCat software (licenses available here online).
Includes:
•PCM
•Cable
•1 license to work with EFI Live – retail value $249
Innovate Motorsports LC-1 Wide Band Controller
Includes:
•LC-1 controller
•Bung
•Serial cable
•Sensor
•CD with software and manuals
•Sticker
•Original box
The LC-1 Lambda cable is a complete wideband controller built in to a sealed cable. It features the same award-winning patented digital measurement principal found in the LM-1 & LM-2, and includes digital input, output, and 2 user programmable analog outputs.
The LC-1 is more accurate than conventional designs costing many times as much, and its self-calibrating circuitry can compensate for changes in temperature, altitude and sensor condition. The LC-1 is ideal for applications such as Dynos, Data Acquisition, Standalone ECUs, piggyback fuel controllers, OBD-II software or chip programmers, and gauges. With the LC-1, you can add additional wideband channels to your LM-1, convert an existing narrow-band gauge, or add wideband capabilities to your dyno. You can even tune individual cylinders by using multiple LC-1 kits.
