Please allow me to introduce myself
I'm not interested in turning my car into a drag strip monster but rather a road course/daily driving machine. I purchased my car brand new back in December 2001 and it has 118,000 miles on it. The car still runs wonderfully and has given me few problems along the way. I just upgraded and added most suspension options as the rear end was really starting to wear out and even from the first day I drove the car, was quite disappointed with how much it would sag. My prior two cars were a Dodge Stealth R/T Turbo and my dad's '01 Z06, the latter I had the privilege driving everyday for a little over a year when he was overseas on business
Needless to say, I was very happy with my T/A from day one, except for the handling- Everything else was a dream come true and in many aspects, I thought it beat out the other two cars in many aspects- Neither the Corvette or the Stealth had t-tops and I personally liked the outside looks and interior creature comforts (such as comfortable and adjustable side-hugging seats and that Hurst shifter) of the T/A more. Anyway, I'm mainly here to get some quality advice on my suspension setup as well as affordable horsepower upgrades and the rear end gearing that I may need to go with them.
Thanks everyone and I'm happy to finally be a member!
Being an inexperienced racer you should hold off on adding any power until you get a lot more seat time, as adding more power may make your times SLOWER due to having trouble getting that power to the ground.
Some quick notes:
Search the suspension section thoroughly before you buy anything.
The "tried and true" suspension setup for these cars for handling is the koni/strano setup, you won't find a better off the shelf setup.
-Stay away from drag shocks (viking, afco, QA1, strange, etc) - only going to make you slower and the car will be loose and floaty.
-Stay away from cross drilled rotors unless you like cracks. Blank rotors + good pads will give you great braking power.
-square tire setup (17x11's all around with 315/35/17s are ideal) for best balanced handling, no staggered.
-No poly bushings in control arms, they need articulation and poly will cause bind. Rubber or rod-ended only.
-Keep the stock rear end, a 12 bolt or 9" will be heavier and not ideal for handling.
Focus on suspension and brakes and making the car durable on the road course before anything else.
