New to LS
Old Dec 29, 2014 | 03:48 PM
BufordC10's Avatar
Default New to LS
Have been looking around for a while and have just registered.
Learning all I can on an LS swap for an 1985 C10 2WD that I will be working on with my daughter.
Want to do a Truck 5.3 with the 4L60E trans. with A/C. Starting to source the engine now with a couple of scrap yards and saving money!!!
Thanks for all the info that has been posted. It really has me stoked!!
Old Dec 29, 2014 | 04:06 PM
76larkman's Avatar
not terrible looking project truck. 03 & newer are drive by wire throttle so you will need gas pedal/tack box & harness as well pcm of course. Try to get everything you can with it, any bolts, clutch fan, engine harness, air cleaner box, ETC. LT1Swap.com has info to modify truck harness, time consuming but easy enough to do yourself. Good luck.
