New member in need of advice!
Old Feb 13, 2015 | 11:09 PM
funkytekno's Avatar
Default New member in need of advice!
Hello,
I am not very knowledgeable but I am getting ready to pull the trigger on a LS6 crate engine to drop in my blown 98 trans am (ran oil dry).
I was quoted for the LS6 this a slightly beefed up ls6 that claims 450hp at $5,700. Quoted $1,500 for the swap.
LS6 specs:
Cubic Inch / LTR's:
350 / 5.7
Horsepower:
450
Ft. Lbs. Torque:
440
Compression:
10.5:1
Aspiration:
Normal
Rev Limit RPM:
6600
Block:
Cast Aluminum
Bore x Stroke:
3.900" x 3.620"
Crankshaft:
Nodular Iron
Rods:
Forged Powdered Metal
Pistons:
Mahle Forged
Heads:
Cast Aluminum
Chamber CC:
64.5cc
Intake Port CC:
210cc
Intake Port Style:
Cathedral
CNC Ported (Y/N):
No
Intake Valves:
2.00"
Exhaust Valves:
1.55"
Valve Springs:
GM HD Beehive
Retainers:
Lightened Chromolly
Rockers:
1.7:1
Pushrods:
5/16" x 7.400" .080" Wall Chromoly
Lifters:
Delphi Hydraulic Roller
Camshaft:
Hydraulic Roller
Timing Chain Set:
Single HD Roller
I chose the ls6 because from what i have read, it would be a straight swap and I could reuse all my original accessories. I would like to know if there are better options for wanting as much rwhp as i can get and still pass smog in CA.
I have read that a ls2 would be better for power but much more difficult to swap.
What other parts am I going to have to replace if I go with the LS6? Rear end, drive train? Rebuild rear end or replace gears?
Last thing is if I do go with the LS6 is there anything I should replace while the engine is out to save some cash?
Thank you in advance for any advice.
Ryan
