New from michigan
glad to be on this site!
ive had this car car for a few years now been doing what i can to it! ive done all the work my self other than tunning. learned a lot so far! lots of good info on this forum!
2000 trans am ws6 6 speed
recently painted still putting back together slowly.
-performance.
ls2 6.0L "year 2005 24x reluctor" low mileage
port/polish 243 heads
fast 102mm LSXR intake
bigmouth 102mm Throttle body
ls2 injectors w/wire conversion #80501
racetronix fuel pump w/wire harness
.650 patriot gold lift springs
T-Rex v.2 242/248 - .608/.612 - 110LSA
matching push rods "comp cams"
slp under air dam/ram
slp maf
slp air lid
*would like to spray the motor in the future
new
Knock sensors
cam/head gasket set
headbolts
intake bolts
harmonic balancer bolt
t56 transmission stock
center force clutch
tick performance adjustable master cylinder
stock drive shaft
-suspension
rear end
Moser 12 bolt
35 spline
4.30 gears
kyb adjustable shocks
umi torque arm
umi LCA's
umi cross member safety loop
umi panhard bar
umi 3point SFC's
NT05R Drag Radials 315-35-17
only video i really have.. me and a friend messing around a little.. my trans wont shift at high RPM's plan on getting a rebuild stage 2
