Aussie BMW E36 L98/T56 Swapper...
Id be interested to understand the teaction control wiring and the numbers of VSS notches on the corners of a commodore? ie I wonder if a BMW signal could be plumbed into the VE Traction Control to retard torque etc in a swap like this? BMW has ABS and the next model had Traction Control, but it does have VSS hall effects on each corner.
Also am keen to understand the "5 wires" required to hook up a VE ECU to the BMW... Im assuming that the BMW body computer (OBDII) with its securty system is what gives the VE ECU its ignition power, once the BMW ECU has its security system appeased (key RF Id)?
Thanks in Advance
