5.3 turbo build help
Ok I'm doing a turbo 5.3 build and have a few questions ive done a ton of reading but can't find a straight answer so I plan on doing ls6 cam do i need move the sensor? If so does comp make something similar to ls6-? Will stock push rods work? Do I need injectors/fuel pump? Should I run the stock truck intake I e head good things about it and the motors going I a truck so clearance isnt a problem. What is the ring gap I need? What kinda numbers do you think id see I'm hoping for close to 500 at the wheels? And I'm running a cheep ebay turbo btw but Any help in much appreciated
