Impala SS Newbie
Old May 11, 2017 | 05:22 PM
Ralphsmith_jr's Avatar
Default Impala SS Newbie
Hi guys, im new to the forum and searching everywhere to find some info out but don't see what I'm looking for maybe you could point me in the right direction. 1995 impala ss, drove car to spray off undercarriage (did not spray opti) left the car running the entire time, get home park the car go to move it minutes later and nothing. No click no power to starter, no accessory lights, only thing on the dash that works is the odometer along with the gauges moving when the key is forward. Radio works fine headlights work fine AC blows car will not crank. I tried putting a resister to the vats and nothing, I pulled the PCM cleaned it put it back in and checked all fuses. I also pulled the battery for 30 minutes put the battery back in same thing still no power to the ignition switch under the hood. Thanks in advance ce any help would be greatly appreciated
