New to the forum
Injectors (Make/Model/Size): Accel Performance Fuel Injectors
Throttle Body Size: 58mm
Cold Air Intake
Intake Manifold Fully Ported Pacesetter Long Tube Headers 1 3/4" to 3" collector
Catalytic Converters Delete
Magnaflow catback
EGR, Air Pump Delete
Torqhead Coil Conversion/LS PCM Kit
Camshaft (Make/Model/Specs): Lloyd Elliott Custom Grind 227/235 .565/.579 110 LSA camshaft
Cylinder Head Specs: Lloyd Elliott LE2 Heads Manley 2.00/1.56 6000 series valves, Lunati Double Springs, Steel retainers and locks, 205 cc intake port, 275/190 CFM
Rocker Ratio: 1.6:1 roller rockers
Torque Converter (Make/Stall): Yank Stealth Thruster 2800
Polyurethane Motor/Transmission Mounts
I have plans to do more upgrades later in the year. Looking forward to using the forum for help and providing help whenever I can.
