Another One...
I'm from the Phoenix area and am in the process of building a 57 Chevy Pickup. It's a ground up build, the stock frame rails are being reinforced with channel stock and a x-member will be incorporated into the frame design. The truck will get a "No Limit Engineering" coil over suspension front and rear. Wideride IFS and a Fat Bars 4 link setup out back. I'm planning to go 4 wheel disk brakes without a power master cylinder. A 9' ford for a rear end with a Tru Trac with 35 spline axles. A T-56 Magnum or a TKO 600 for the finding the right gear for the moment or situation. For me simplicity is king. I have been thinking about building a Carb'ed 408 LS. Looking forward to learning more about these engines.
