Always playing around...
Old Feb 4, 2021 | 08:58 PM
CobraLS's Avatar
Default Always playing around...
So I am hoping to find possibly someone who has experience with an LS in a boat. I have the 6014 box, and one of my concerns is that it continues to set the cam sensor fault (rear sensor) which I have replaced twice now, with no change. I am a bit unclear about the pin problem that I understand really only applies to the extension harness for front cam sensor, but would be pleased to be corrected. I have checked, and the harnesses do go to the correct sides. I have gone through grounds, and feel confident on that end of things too, and would just like to find the reason for this little problem, although I do not feel it is negatively affecting performance. My main objective here is to find a way to accomplish ignition interruption to facilitate shifting. If MSD would alter a 6014 for me, so that I could momentarily apply 12 volts to the blue wire (launch rev limiter), but the preset minimum is 2000 rpm. If this could be dropped, I think that would work, but I guess I need to find another way. Any suggestions here would be greatly appreciated.
