Forums available?
Old Sep 2, 2021 | 05:49 AM
jjzepplin's Avatar
Default Forums available?
I am new here and have 3 LS projects.
#1 - 1999 5.7 - T56 swap into a 72 2WD Blazer
#2 - 2006 6.0 LQ9 with New AFR heads to replace the 5,7 eventually
#3 - 2104 GMC 5.3 6L80 Shortbed standard cab - have lowering kit and Speed Engineering headers to install
I also just received my HPTuners kit.
Question is - Where do I start these posts?
I don't want to put them in the wrong areas.
Old Sep 2, 2021 | 02:42 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
For all matters relating to your LS swaps into non-LS vehicles, please use the Conversions & Hybrids section, located here: https://ls1tech.com/forums/conversio.../?daysprune=30
For matters related specifically to your late model truck, you're probably best off using our sister site, https://www.performancetrucks.net/forums/ , it was spun-off from a truck specific section that used to be located here on LS1Tech.
Hope that helps.
Old Sep 3, 2021 | 05:36 AM
jjzepplin's Avatar
Awesome! Thank You so much!
