New to Forum
Old Jun 14, 2026 | 06:11 PM
Sfish's Avatar
Default New to Forum
Hi everyone I am new here. I recently bought a 63 GMC with an LS swap,,Camaro front end and 9inch rear end. I will have a ton of questions. Have been a SBC guy my whole life as well as my 2 Hot Rod brothers. First issue is steering. In a very short time I have been through 2 rag joints! Linkage or steering box?
Old Jun 14, 2026 | 06:23 PM
Doug G's Avatar
Welcome to LS1...Have you thought about a double D shaft and U-joints ?
Must have some bad alignment or binding ?
Old Jun 14, 2026 | 06:35 PM
Sfish's Avatar
I had it repaired out in Vegas where I bought the truck. The mechanic said I may have to replace the steering box at some point! Literally after I took it off the transporter here in Myrtle it broke again. So how do I know if it's the alignment (which is pretty radical) or the steering box?
Old Jun 15, 2026 | 06:26 PM
Doug G's Avatar
Alignment of the steering shaft to the box... should be a straight line with a rag-joint as they don't like angles V
Old Jun 16, 2026 | 11:36 AM
Sfish's Avatar
Well that is the problem bcz there are multiple angles!. Any suggestions for a solution? Somebody out there must have faced this same problem bcz I have read that it was a popular front end swap back in the day. I'll try to get a decent picture.
Old Jun 16, 2026 | 06:09 PM
Doug G's Avatar
unsure what you'll need, but here
Zig's Street Rod - Steering - Components
Old Today | 06:05 AM
Vokes's Avatar
Welcome to the forum
