LS1 & Internet Acronyms - Defined
Old Jul 31, 2012 | 11:42 PM
  #141
EricaLynn's Avatar
Thanks for posting this, I thought I knew what most of these were until I browsed through the list and realized there were about 2 billion acronyms lol.
Old Jul 31, 2012 | 11:56 PM
  #142
omgitsmikeyc's Avatar
Thanks for the link, I'm sure I'll be pulling it in front as I go through these threads.
Old Nov 24, 2012 | 12:18 AM
  #143
V8roar's Avatar
Originally Posted by Bruce Pittman
when you "bump" a thread, usually and ad WTB/WTT/WTS, its the same as doing the TTT to bring, or "bump" the thread back to the top of the listings
B.U.M.P.
means Bring Up My Post
Old Jan 26, 2013 | 01:09 AM
  #144
jacobdztech's Avatar
New here, the list would be helpful, but it is not working for me. Is anyone else having this problem?
Old Mar 14, 2013 | 10:28 AM
  #145
Alan F's Avatar
Ditto.
Old Jul 8, 2013 | 04:12 PM
  #146
tiger710_82's Avatar
Click the link = page not found. Is there a new link?
Old Jul 8, 2013 | 07:47 PM
  #147
admoore's Avatar
Default Wanted to Read.... Its not here
The link must be broken, this is upsetting.
Old Jul 18, 2013 | 03:50 AM
  #148
Smokey626's Avatar
Link doesn't work for the FNG from MN either...
Old Aug 31, 2013 | 08:27 AM
  #149
Zipper's Avatar
Lightbulb Link broke for me too
Using the Way Back Machine (http://web.archive.org/web/201209170.../acronyms.html) I was able to find this:
! - using this before an acronym means removal of that item from the vehicle (example: !EGR)
  • 1/4 - Quarter Mile (drag racing)
  • 1LE - Suspension Handling Package Option
  • 2WD - Two Wheel Drive
  • 4L60E - actual part name for the Automatic 4-speed transmission
  • 4L65E - medium duty 4-speed automatic transmission found in some trucks
  • 4L80E - heavy duty 4-speed automatic transmission found in some trucks
  • 4WD - Four Wheel Drive
  • 700R4 - older generation 4-speed GM automatic transmission
  • A3 - 3-speed automatic transmission
  • A4 - 4-speed automatic transmission
  • A/F - Air Fuel Ratio
  • AIR - Air Injection Recirculation (part of emissions system.)
  • APHR - Adjustable Panhard Rod (Suspension)
  • AFR - Air Flow Research (Vendor)
  • ASP - Automotive Specialties Performance (Vendor)
  • ASR - Camaro version of traction control
  • ATF - Automatic Transmission Fluid
  • ATI - Supercharger Company (Vendor)
  • AWD - All Wheel Drive
  • B4C - Police Package Option
  • BBC - Big Block Chevy engine
  • BBDC - Before Bottom Dead Center
  • BDC - Bottom Dead Center
  • BHP - Brake Horsepower
  • BOV - Blow Off Valve (turbo related)
  • B/O - Bolt-On Modifications
  • BSM - Body Side Moulding - door ding guards on your doors.
  • BTDC - Before Top Dead Center
  • BTW - By The Way
  • C5 - Fifth Generation Corvette (1997-2004)
  • CAGS - Computer Assisted Gear Selection (the "skip-shift" on MN6 cars.)
  • CATS - Catalytic Converters (emissions/exhaust system)
  • CAI - Cold Air Induction
  • CCLB - Crew Cab Long Bed Truck
  • CETA - Collector Edition Trans Am (yellow 2002 model)
  • CI - Cubic Inches (engine displacement)
  • CKP - Crankshaft Position (sensor)
  • CME - Center Mount Exhaust (SLP brand system)
  • CMP - Camshaft Position (sensor)
  • CONV - Convertible
  • CR - Compression Ratio
  • DEG - Degrees (timing or temperature)
  • DRL - Daytime Running Lights
  • DR's - Drag Radial Tires
  • DSL - Driveshaft Safety Loop
  • DTC - Diagnostic Trouble Code
  • ECM - Engine Control Module
  • ECSB - Extended Cab Short Bed
  • ECL - Exhaust Lobe Center Line (camshaft)
  • ECT - Engine Coolant Temperature (sensor)
  • EGR - Exhaust Gas Recirculation (emissions system)
  • EGT - Exhaust Gas Temperature
  • E/T - Elapsed Time (drag racing time measurement)
  • FAST - Fuel Air Spark Technology (Vendor)
  • FBODY - GM chassis designation for Camaro/Firebird
  • FI - Forced Induction (turbos, superchargers)
  • FIPK - Fuel Injection Performance Kit (See K&N)
  • FMIC - Front Mounted Intercooler (turbo)
  • FMS - Futral Motorsports (Vendor)
  • FMU - Fuel Management Unit
  • FPR - Fuel Pressure Regulator
  • FPSS - Fuel Pressure Safety Switch
  • FRA - "Free Ram Air" modification
  • FRC - Fuel Rail Covers OR Fixed Roof Corvette (hardtop Vette)
  • FLP - Finish Line Performance (Vendor)
  • FTRA - Fast Toys Ram Air (product)
  • FWD - Front Wheel Drive
  • FWIW - For What Its Worth
  • GMMG - Vendor known for producing modified GM backed F-bodies H/C - Heads and Camshaft
  • HO2S - Heated Oxygen Sensor
  • HP - Horsepower
  • HPE - Horsepower Engineering (Vendor)
  • HPP3 - Hypertech Power Programmer 3 (product)
  • IAC - Idle Air Control (solenoid)
  • IAT - Intake Air Temperature (sensor)
  • IC - Ignition Control Circuit
  • ICL - Intake Lobe Center Line (camshaft)
  • IGN - Ignition
  • IMHO - In My Humble Opinion
  • IRS - Independent Rear Suspension
  • K&N - Brand name of air filter
  • KR - Knock Retard (tuning)
  • LCA - Lower Control Arm (suspension)
  • LGM - Lou Gigliotti Motorsports (Vendor)
  • LM - Loud Mouth (exhaust system by SLP)
  • LMAO - Laughing My *** Off
  • LOL - Laughing Out Loud
  • LPE - Lingenfelter Performance Engineering (Vendor)
  • LQ4 - iron block, LS1-based 6.0L truck engine
  • LS1 - Generation 3 GM smallblock V8 engine (introduced 1997)
  • LS2 - Generation 4 GM smallblock V8 engine (introduced 2005)
  • LS6 - Generation 3 GM smallblock V8 found in Corvette Z06 (introduced 2001)
  • LSA - Lobe Seperation Angle (camshaft)
  • LSS - Lou's Short Stick (shifter handle)
  • LT - Long Tube Headers
  • LTFT - Long Term Fuel Trim (tuning)
  • LTRIM - Long Term Fuel Trim (tuning)
  • M6 - 6-speed transmission
  • MAF - Mass Air Flow sensor (measures amount of air entering intake)
  • MAP - Manifold Absolute Pressure (sensor)
  • MAFT - Mass Air Flow Translator (product)
  • MN6 - Option code for factory 6-speed transimission.
  • MTI - Motorsport Technologies, Inc. (Vendor)
  • N/A - Naturally Aspirated (all-motor)
  • N20 - Nitrous Oxide
  • NBM - Navy Blue Metallic (color)
  • NOS - Nitrous Oxide Systems (brand name)
  • NWS - Not Work Safe (do not click link if you are at work, unsuitable material inside)
  • O2 - Oxygen Sensor
  • ORY - Off Road Y-pipe
  • ORP - Off Road Pipe
  • PCM - Powertrain Control Module (your vehicles engine/tranny computer)
  • PCV - Positive Crankcase Ventilation (emissions system)
  • PE - Power Enrichment (tuning)
  • PHR - Panhard Rod (suspension)
  • PITA - Pain In The ***
  • POS - Piece Of ****
  • P/P - Ported And Polished
  • QTEC - Quick Time Electric Cutout (product)
  • QTP - Quick Time Performance (Vendor)
  • RCSB - Regular Cab Short Bed Truck
  • RCLB - Regular Cab Long Bed Truck
  • ROFLMAO - Rolling On Floor Laughing My *** Off
  • RPM - Revolutions Per Minute (engine speed)
  • RWD - Rear Wheel Drive
  • RWHP - Rear Wheel Horsepower
  • RWTQ - Rear Wheel Torque
  • SAE - Society of Automotive Engineers
  • SBC - Small Block Chevy engine
  • SC - Super Charger
  • SES - Service Engine Soon lamp (on dash)
  • SFC - Subframe Connectors
  • SLP - Street Legal Performance (Vendor)
  • SOM - Sunset Orange Metallic (color)
  • SOTP - Seat Of The Pants
  • SS - Super Sport
  • SSLE - Super Sport Limited Edition (2002 Anniversary package)
  • SSRA - Super Sucker Ram Air
  • STB - Strut Tower Brace
  • STFT - Short Term Fuel Trim (tuning)
  • STRIM - Short Term Fuel Trim (tuning)
  • T56 - actual part name for the M6 transmission
  • TA - Trans Am
  • TB - Throttle Body
  • TBODY - Throttle Body
  • TBRAKE - Transmission Brake
  • TEA - Total Engine Airflow (Vendor)
  • TC - Torque Converter
  • TCS - Firebird version of traction control
  • TDC - Top Dead Center
  • TFP - Transmission Fluid Pressure (switch/valve)
  • TH350 - Turbo Hydromatic 3-speed automatic transmission
  • TH400 - Heavy Duty Turbo Hydromatic 3-speed automatic transmission
  • TNT - Texas Nitrous Technologies (Vendor)
  • TP - Throttle Position
  • TPiS - Tuned Port Induction Specialties (Vendor)
  • TPS - Throttle Postion Sensor
  • TQ - Torque
  • TR - Thunder Racing (Vendor)
  • TSP - Texas Speed & Performance (Vendor)
  • TT - Twin Turbo
  • TT2 - Torque Thrust 2 (type of wheels by American Racing)
  • TTOP - T-Top roof
  • TTT - "To The Top"
  • UCA - Upper Control Arm (front suspension)
  • VATS - Vehicle Anti-Theft System (the coded chip in your ignition key)
  • VERT - Convertible
  • VSS - Vehicle Speed Sensor
  • WB O2 - Wide Band Oxygen Sensor
  • WOT - Wide Open Throttle
  • WS6 - Firebird Performance "Ram Air" Package (RPO code)
  • WTB - Want To Buy
  • WTF - What The F-ck?
  • WTT - Want To Trade
  • WU8 - Camaro Performance SS Package (RPO code)
  • Y2Y - Exhaust Upgrade Option Code for SS Camaro (Dual-Dual system)
  • YBODY - GM chassis designation for Corvette
  • Z06 - Corvette Performance Package, based on hardtop body (RPO code)
  • Z28 - Camaro equipped with V8 engine (RPO code)
  • ZL1 - Camaro Modified by GMMG and equipped with LS6 or 427ci engine
Old Mar 10, 2014 | 07:11 PM
  #150
fordkilla2000's Avatar
when clicking the link it redirects and shows nothing
Old Jun 14, 2014 | 07:19 PM
  #151
Iroc_Rat's Avatar
Its showing an empty page sayiong what your looking for is not here.
Old Oct 12, 2014 | 06:57 PM
  #152
dcatlin's Avatar
I just wanted to say hello, I am doing a 6.0 swap into a 1984 silverado 4x4 short box. I am up north in upstate ny where the salt wins the fight every year. and carbs don't like the cold. my truck just arrived from n.c., her body is clean, but needs an interior, and a heart transplant. great site here I love all of the info available. My v 8 bike I am building will be carburated, see youtube under dcatlin for that project.
Old Dec 1, 2014 | 11:15 AM
  #153
seebs01's Avatar
New Guy here,son and father .
1996 slp ss z/28. Yes it's real. .Always looking for some help with these things.
Any quick tips on bleeding the cooling system?
Old May 23, 2016 | 11:42 AM
  #154
Suspiciousminds's Avatar
Default Link doesn't work
At least not for me it doesn't. All I get is "This is somewhat embarrassing, isn’t it? It seems we can’t find what you’re looking for. Perhaps searching can help."
Nevermind, as I see someone posted them on the last page.
Old Mar 18, 2019 | 10:54 PM
  #155
Rpbj77's Avatar
is the list no longer posted? link doesn't seem to be working
