Newbie Check-in
The 95 Imp is my stock daily driver. It is DGGM (Dark Gray Green Metallic) with 141K miles. I am the second owner. I found it as a trade in at the local VW-Subaru dealership with 49k on it in '97.
The 65 I have owned since '87. I have been completly thru it. It is a small block/automatic/facotry A/C car. It appears stock (only internal mods). A/C is converted to R-134 refigerent. It has the original block and heads 300hp/ 327 ci motor. It was bored out and added bronze valve guides and seats for unleaded fuel. The compression was bumped back to 9.5/1. Pertronix ignition is hidden under the old style distributor. I dumped the PG tranny and put in a 700r4 but kept the factory floor shifter. I added aftermarket cruise control. It now can get 20 mpg on the road.
Both of the Imps have done the Long Haul on the Hot Rod Power Tour. The Goat gets a chance this year.
See you on the road.
