SS Camaro running rough
Old Sep 7, 2006 | 10:40 AM
SSCamaro00's Avatar
Angry SS Camaro running rough
it started the other day but wasnt that bad. i went to autozone got the scan done. an this is what came up. misfire in number 6. o2 sensor bought one of those to put in bank 2. im going to take a look at the wire an plug for 6. the question is-- would the o2 sensor that is bad make the car run rough??? please help.
Old Sep 7, 2006 | 11:29 AM
SS#2906's Avatar
The O2 sensor would normally make the service engine light come on. Wouldn't be the cause of the rough idling. I just had the same problem a couple of days ago, misfire on 4 and 5. I changed the plugs and the wires, still nothing. I ended up disconnecting the battery(apparently this resets the ECU I've been told) and I turned it back on. Purrrred like a kitten.
Old Sep 9, 2006 | 04:34 AM
SSCamaro00's Avatar
Default still running bad
i replace all the plugs an wires. car still running bad. im thinking bad coil. but i really not sure. need to get test done again. ill will post what the problem is when i figure it out.
Old Sep 9, 2006 | 02:54 PM
SSCamaro00's Avatar
i changed the coil today. still running bad. i got the test done again, is said something about the injectors. plus the mis is 6. i give up. call the dealer.
Old Sep 9, 2006 | 03:40 PM
Azrael's Avatar
It could be the injectors if you have tried everything else. Cylinder 6 is the third back from the front (or second from the rear) on the passenger side.
8---7
6---5
4---3
2---1
