Got Questions!
Im new and just signed up. I found a 93 firebird for cheap that could use a new engine. owner says the cat may be stopped up and not sure if that is what is causing the engine problems. i want to buy and put a v8 in it but not sure how big the job will be. i have a 305 from an 89 camaro but would i be better of just buying a better v8 or if i did buy a new v8 would the swap be hard??? im just getting started with this kind of project and need a lil help. Thanks
someone help.. im the cousin that says its moronic to do a 3.8 swap into a 3.4 UNLESS the engine is shot... and also says its too much of a pain FOR HIM to do a 3.4 94 swap to a ls1.. or even an lt1....
i tried to explain that i had a 99 firebird once upon a time along with a 99 ls1 longblock... MANY extra parts and i was still looking at spending about a 1500-2000 grand in parts.. .along with work.. which he doesnt know how to do... and has no close friends that would be abloe to do it for a deceant price.
if you have a house with a garage, then you can do it, but budget 3x your initial budget because that is what it usually balloons to.
