Hello
Old Mar 13, 2008 | 07:53 PM
canada4g63's Avatar
Default Hello
I own a 2000 Camaro SS here are the specs.
ENGINE
RevXtreme 408 cid Iron Block
Harland Sharp 1.7 Adjustable Roller Rockers
RevXtreme/Felber Race Heads
Comp Cams Chromoly Pushrods
Comp Cams Lifters
Roll Master Dual Roller Timing Chain
Cometic Performance Gaskets
Keyed Balancer
Callies Rotating Assembly
Diamond Forged Pistons & Accessories
RevXtreme �Big Dog� Cam
Fast Intake 90mm Manifold
Fast 90mm Throttle Body
Meziere Electric Water Pump
SLP under drive pulley
MSD Super Conductor Wires
Nitro Dave�s Stand Alone Aluminum Fuel Cell
NITROUS SYSTEM
NX EFI8000 200-500HP Direct Port Nitrous Kit with 15lb Bottle �6 line
NOS 5177 Dry Nitrous Kit
Custom Nitrogen Push System
Aeromotive Fuel Rails
EXHAUST
3.5 inch all mandrel bend custom with dual 5-inch Dynomax bullets
QTP 1 7/8� Long Tube Headers
SUSPENSION & CHASSIS
BMR Adjustable Torque Arm
BMR Full Length Relocation Cross Member
BMR Upper and Lower Tubular A Arms
BMR K Member
BMR Moly Adjustable Race Control Arms w/relocation brackets
BMR Moly Adjustable Race Pan Hard Rod
BMR Xtreme Duty Rear Drag Race Swaybar
TRANSMISSION & DRIVETRAIN
Spec Stage 5 Billet Steel Flywheel
Spec Stage 5 Pressure Plate
Spec Stage 5 Disc
ACPT Carbon Fiber Drive Shaft
Ford 9 inch Custom F-body rear w/ spool and 35 spline axles
Old Mar 13, 2008 | 07:59 PM
Castle's Avatar
Welcome!
Very impressive list there!
Pics pics pics!
Old Mar 13, 2008 | 08:22 PM
blown03mustang's Avatar
very nice, welcome to the site
