JPR statement
How much money do you owe Jay Fisher? When will he be getting his money?
When will 11Bravo be getting his engine?
Are you going to fix Bear's engine, Joe, or is that JD's responsibility?
When will MikeK. be receiving these new heads you promised him?
Are there ANY happy and satisfied JPR customers left? I would love to hear from them. Are there any engines that did not blow up, burn oil, lose coolant, collapse lifters, spin bearings, destroy cams, melt pistons, etc... due to your incompetence (or one of the many conspiracies you fell victim to)?
What happened to the guy who dynoed the big numbers over at SLP? Is he happy? Is his car still running?
What happened to the big story GMHTP was supposed to be doing on your car?
Can you update us on the status of the mythical JPR EWP?
BTW, my car dynoed 422 at JD's but never repeated those numbers or ran well at the track with your package- subsequent dyno numbers were 392, 390, and finally 407. All after changes that sould have increased power- new shortblock, Crane dual springs, YT roller rockers, new lifters (they had collapsed), repaired JPR heads (loose intake valve guides, missing spring seat), several dyno tuning sessions, Meziere EWP, new Y-pipe, delete cats, new catback, etc...Best MPH at the track was 110! Bolt-on cars can run that! Can you explain any of this? All the components of my engine are top notch, I spared no expense...the only weak link I see is the JPR HVLD heads.
I am the guy who put down numbers at SLP. The car still makes great power, but only after I spent another 8-9k to fix it all. It is now for sale. My shortblock was never touched except for the cam. Maybe that is why I am one of the lucky ones?? My car ran 11.3@124. At least it ran what it should.
2 things that strike me as odd...1st - Your happy now that he has fixed everything, but Im assuming your sig refers to your first setup -the "lean up top", "dropped compression on 2 cylinders" and "Never Runing right!" Most vendors dont have these problems which lead to failures and having to go back and fix things.
2nd - Why isnt JPR building your 355? I see you are going with APE now...
I am done with JPR, JD and everyone named Joe. If U wanna make me a happy customer send me a check for $1000 so we can split the rebuild of my motor. Im done!!!!
man 8-9k to fix it all? what the h*ll happened? or did you try and get it fixed through JD and it was $1k per quart of "gray wolfe" oil he put in??
He's not doing my 355 because frankly, I got pointed in the direction of APE first and after talking to Brian and Chris was sold. And the price was VERY budget friendly to me. That by no means doesn't mean I wouldn't have a motor done by Joe.
LMFAO. So how much did you get under the table to make that statement. You sir are the needle in the haystack at this point
Hopefully the rebulid goes well for you and its only minor things that need to be changed.
Maybe we can all setup a charity something like helpmeputmyJPRmotorbacktogether.org
Im afraid that there is no salvaging what happened in the past with most of these people. My commentary is about the best you are going to get:
I think in your mind you tried to do the right thing (including some payments to JD for screwups for him to cover for you), I really do not believe you set out intentionally to screw people. You did some nice things for me like driving my car to my house 2 hrs to get some break-in miles and then riding back 2 hrs to the dyno. But then you did some seriously f*cked up things like not calling me back when JD was telling me it was $7k to rebuild it ( Im sure you listened to my messages, read my emails, so saying that JD just told you to sit in a f*cking corner, shut and port heads doesnt explain not calling me back), forgetting several times that I was trying to get the massive oil burning issue fixed, and many of these other things I have read from and talked with your other customers about.
The make the situation worse, you joined up with JD, who somehow things everyone owes him something (and isnt afraid to charge them extra for it), has no understanding apparently at all about how an LS1 works and certainly no clue on how to build one (its exactly like a mustang motor, right joe?), and doesnt have any kind of customer service sense. Thats also my nice version of the comments for him.
Cut your losses and move on -- hopefully you have learned something from this whole experience.
George Cully’s build was supposed to be an easy job until it was insisted that the old motor was blown from water ingestion and to have the insurance company pay for it, so it was inspected and I gave the insurance company some story that the motor had to be replaced and I was cut a check and applied it towards my Camaro motor and sent a check of 5,000.00 to him back in SC. When I freshened my Camaro motor before the install into his Vette, I used the Fel Pro engine kit with the now known to be bad undersized –o- ring for the oil pump and the pressure really wasn’t right especially after the dyno tune session and took out the crank, we found out later that the Fel Pro –o- rings are not to be used. Duh, The job was turned over to JD's and I paid 4,000.00 to fix that motor. Hindsight being 20/20 I shouldn’t even accepted the car off the carrier, but I didn’t what I was getting myself into and I will leave it at that. now has oil pressure issues again
Secondly Joe, I did not have to twist your arm to take my 50% deposit in Aug. However, AFTER you got my money I had to twist YOUR arm before YOU would take shipment of my car (in Sept). Then I had to twist YOUR arm to put your “FRESHENED” engine in my car (which was already on the ground-literally). This ONLY took you until the end of Dec. Not bad considering that you had been paid MORE than the job called for. But I did eventually get MOST of my money back from you. (The $5000 did not cover it either.) I just NEVER got the engine I paid for.
AND as of today... I now KNOW why my engine still has NO oil pressure. I talked with Brian and he told me that you had your hand in helping make decisions on my motor. He said you were trying to save a dime and thus I still have the same bag of sh*t. I can't believe that JD allowed you to make a decision that he signed his name to. None-the-less, between the 2 of you I still do NOT have an engine and your 12 month/24,000 mile warranty is joke. Unfortunately, the joke is on me.
But instead of me making claims let me just post a picture (courtesy of JD) of your “Freshened”
engine that you installed in my car. JPR
Tech Addict Join Date: Feb 2002
Lots of good new parts and motors F/S
I have an exciting new project coming up and I will have no need for these parts anymore .
All part pricing is not really negotiable and buyer pays shipping unless specified (shipped)
1. ASPT Carbon Fibre driveshft, paid 700.00 just recently $450.00 used for 3K in perfect condition, 10 bolt yolk U joint, I have the receipt.
2. 346 ci Z06 short block with forged pistons.
Z06 windage tray (of course)
Diamond forged gas ported 2 cc relieved pistons.
file fit Diamond rings.
ARP stainless steel Pro series rod bolts.
Fed Mogul racing rod and main bearings.
stock replacement cam bearings.
new timing chain.
new oil pump.
all new gaskets.
Completly balanced rotating recipicating.
$2,500.00 shipped, in use for 5,000 miles, it's perfect with limited warranty.
shape and with a limited warranty
.However. now that it has been rebuilt by JD I feel soooo much better
. (NOT!!)Here are those perfect pics...
http://www.joeprinceracing.com/heads.html
Call the N.J comsumer affairs dept.
Is his website really back up, or is that just a cached old page?
Just wondering because it doesn't look any different, and the link to the home page doesn't work.
