LS1TECH Sponsor Feedback Tell us about your sponsor transactions
QTP wiring sucks A$$
Old May 28, 2004 | 01:10 PM
Scott 00TA's Avatar
Angry QTP wiring sucks A$$
After I have waited for like three weeks to get my electric cut-out from QTP, I must say that I am horribly disapointed with the wiring! As if the 6 inch long toggle switch that looked like a retarded monkey put together was not hard enough to hide! But to go with it came the bolts on the flowtech that were too short to even get a thread on. After i spent the hours pulling up carpet and my center console, hiding the multicolored monkey switch and putting it all back together again, while I was hooking up the qtec, the conector to the main wire fell off in my hand. Its makng me crazy!
Q uick
T o
P huck you up
Old Jun 1, 2004 | 04:05 PM
Pesticide's Avatar
I found the install not hard at all. The secret is to grind off the studs from the Flowtech cutout and install new bolts. (I sourced mine from the local hardware shop). As far as the switch, I mounted mine at the front of the consul. If you look where you right knee is there is a bolt and backet that works perfect. I just fabbed up a small piece of aluminum and it looks factory.
