7/8" drive chain/gear change
Old Feb 9, 2009 | 10:40 PM
phat_ridegt's Avatar
Default 7/8" drive chain/gear change
thought id see if anyone has upgraded to the 7/8" chain set from zzp? (http://www.zzperformance.com/grand_p...=360&catid=105)
i have this set on my gtp, but i wanted to see if anyone knows if there are any differences in the ls4 spec, 4t65 i should know about. i dont see any reason it wont work...but i would rather find out now, than once its torn apart....
Old Feb 10, 2009 | 12:07 AM
Nacho SS's Avatar
I'd skip the 7/8th or 15/16th sizes if you're making any serious power and go with a 1" setup.
Old Feb 10, 2009 | 07:23 AM
well it takes 450whp to have to worry about the 7/8" (which is stronger than the 15/16), this car probably wont see that, although ill be in that range with the gtp, if you dont beat it much, the 7/8" is fine.
i just need to know if there are any differences between the gtp set, and the gxp set....
Old Feb 10, 2009 | 10:24 AM
cherrygxp's Avatar
nope same tranny
Old Feb 10, 2009 | 10:04 PM
Nacho SS's Avatar
I'd rather have the piece of mind of having an overly-strong tranny. There's other stresses on it than just HP.
