GXP alignment issues
Old Mar 29, 2016 | 09:42 AM
  #41
LeadfootDuramax's Avatar
Your cradle is off. I had the same thing happen. They wanted to do all kinds of crazy stuff and I told them now. When you get under the car, look at the subframe mounts on the passenger side. Near them is a hole in the subframe that should line up with a hole on the body.
You can align it by loosening all 4 subframe bolts slightly and using a prybar or something similar to get the holes in the subframe and body to line up.
Old Mar 29, 2016 | 11:04 AM
  #42
superglide9375's Avatar
yep i did the camber bolt thing neg 1.50 to pos 1.50 i think ill look for my receipts and he got it damn close,within tolerances on one and in green on all others very happy with set up also have adjustable lateral arm s on rear so that also helps,car is on rails man lol
Old Mar 29, 2016 | 11:17 AM
  #43
ih missed it rotten posted the link
Old Mar 29, 2016 | 04:04 PM
  #44
Camber bolts work well for the rear. Since you said 255 I assume you are talking the front. Align the cradle and you will be good to go.
Old Mar 29, 2016 | 07:40 PM
  #45
Yes rear and im having my alignment done today and mech to ck the cradle ffor hole alighnment thanks again ill post pic of sheet tom
Old Mar 31, 2016 | 09:43 AM
  #46
here is sheet
