Installing new TPMS
Old Mar 7, 2009 | 10:50 AM
pro_performer's Avatar
Default Installing new TPMS
How do you get the TPMS system to recognize the new sensors? Is it easy?
Old Mar 7, 2009 | 11:33 AM
Ill_Born_ss's Avatar
It is very easy. Make sure the tire pressures are at correct inflation (to high or to low will cause it not to preform properly)
I do mine with the car running, but apparently its not necessary.
Find a spot away from other cars and buildings.
Your manual tells you how and explains it a little, but if you don`t have one I can find you a link.
Sitting in your car, reach to the controls on the right side and press the information button(little car with the i) until it gets to the PRESS \/ (check mark) to relearn tire positions.
Press the check mark , the horn will honk to tell you it has started and it will within 2 min. honk again to tell you it finished. If it fails, move the car a few feet before you try again.
