Is a Downpipe Worthwhile w/o and exhaust?
But being skeptical of all my exhaust posts is hardly helpful?
P.S. My car has power door locks, I cannot provide you hard scientific data that I do, but I can tell you that when I hit the button they all go up or down. :-)
When I dynoed I got:
Mustang:
240/293
Corrected for Dynojet:
268.8/328.16
Stock at crank:
303/328
That was with Diablo 93 Tune, K&N, Hogan Catted DP, and No Resonator (Not that it does anything)
And to your question... I would question the MAF and spacer, I don't see any reason why the rest of your setup would cause a problem... Tuning in those two mods will be key and if not done properly I could see how you would lose power....
First off, my baseline dyno WAS bone stock. I wanted to know what kind of power/ torque numbers I was starting with so I could determine what future changes were worthwhile. Second, Pete knows what he's doing but you still haven't told me what Correction Factor was used for your run. Example: the Correction Factor used on my baseline run was STD netting me 250.32hp/ 266.89tq. If I change the correction factor to SAE my numbers (for the exact same run) change to 243.40hp/ 259.50tq. The correction factor may be the difference. Third, like you said Ross, just throwing parts on a car can sometimes rob power especially when you don't have the car tuned for the new mods. I've attached my three main dyno runs. The first is the baseline. The second is after rockers, oil restrictive pushrods and computer tune (with HP Tuners). The third is with the Hogan modular downpipe (race pipe installed) and no additional changes made to the computer tune.
Too answer the original question that started this thread, my numbers show a couple hp gain and about 6tq lost after the downpipe install. My guess is that I could probably get a little more outta the DP if I tweaked the computer tune a little more but just throwing it on didn't make much difference.
It kinda makes sense u lot a little TQ. Kinda like some short tube headers you pick up HP but usally drop a little TQ down low.
hahahahaha...
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
