New idea
Old Apr 24, 2009 | 12:01 AM
Panther427's Avatar
Default New idea
So i have done a little research on how to adjust or gear ration based on tire sizes. This is based on the GXP's since we have the staggered sizes
changing from a 255/45/18 to a 255/35/18 drops tire size to 27" to 25"
(25.03) and drop the rears to a 225/40/18(25.09")
By dropping tire Diameter you will change the effective gear ratio. from 2.93 to a 3.16 for a 25" tall tire. A 24" tire would be 3.3:1. A 24" tall tire would be 3.43... This would be bad for fuel milage and be easier to spin the tires. but might help out over all
Old Apr 24, 2009 | 08:14 AM
VenomGXP's Avatar
Wouldn't tire width need to change as well, even by a small margin, when lowering the aspect ratio? Or am I way off? Interesting thought, either way
Old Apr 24, 2009 | 01:10 PM
impala06ss's Avatar
255 is a base number, it would not change nor have any effect on tire height. The 45 / 35 to which was referred is the variable which would change the height, it is the ratio of the the tire width.
Old Apr 24, 2009 | 01:16 PM
BuffaloSS's Avatar
This is common for those that go to the track often. In fact, many people buy slicks a little smaller for this reason.
Old Apr 24, 2009 | 03:15 PM
Panther427's Avatar
Exactally i was just trying to figure out what the effective gear ratio would be by changing the height of tires.
