IAT Temperatures
its been between 75 and 95 outside, my IAT usually starts around 120 and then will drop to within 10 degrees of the temp outside. im going to try to get these as low as possible these
PS
temps are with the ported headlight in
You can get a Heat Soak Reduction kit from Vector Motorsports, which bypasses the internal unit and allows you to mount the new temp sensor out and away from the engine but it must be in the intake airflow.
Here is the link:
http://www.vectormotorsports.com/ind...mart&Itemid=28
-Mike
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
so, I removed my wrap... and while it does get hotter faster, it also cools down a lot faster since the air is able to blow around it once you're moving, and there's nothing holding the heat in around it...
