DIY intake
Old Jun 15, 2009 | 02:22 AM
SigmaX6's Avatar
Default DIY intake
hey im wondering what size/length of tubing ill need to replace the rubber jaggy one between the airbox and the throttle body?. 07 GXP
Thnks
07 GXP
DIY intake
Exhaust
Trifecta Tune
ZZP shift kit
3.29 final gear
TBS
Old Jun 15, 2009 | 04:22 PM
07MCSS's Avatar
I met the Spectre reps at the Power Tour in Bristol, TN this weekend. They set me up with their Spectre 22 degree 3 inch tube and 2 couplers. You will also need to drill a hole in it for the vacuum tube. I also bought the flex tube with air intake mount to snake additional air into the factory air box.
Old Jun 16, 2009 | 01:12 AM
SigmaX6's Avatar
Thanks alot. im just trying to replace the tube portion and into the stock airbox. Ive cut a bigger hole in the front of the air box since i removed the airhorn and dropped in a K&N
Old Jun 16, 2009 | 05:44 AM
Tappeter's Avatar
3 1/4" inside diameter silicone tube. I used 45 degree and trimmed the ends a little with a razor.
