Alternative intake setup?
Old Jun 25, 2009 | 10:41 AM
Bryan921SS's Avatar
You have you engine cover on wrong....just an FYI
Old Jun 25, 2009 | 10:52 AM
06 SS's Avatar
looks like my post this morning did not make it, will try again;
on the open filter intakes. They are not testing the intake, even if they use a dyno. The hood is up, all they are testing is an open filter in open, relatively cool air vs underhood air. Of course they are going to show a gain over a stock system that draws a more convoluted path through the standard intake instead of an open filter in ambient temps.
I have seen a few closed hood dyno sheets on other vehicles and they did not show a measurable difference in power over a stock set-up.
A difference/improvement in throttle response almost always means a leaner mixture. Of those that have an aftermarket intake, did you have to change your fueling, richen it up?
If you are lean, you get great response, but you also get knock and rapidly rising cylinder temps, neither of which is a good thing for power.
I think the smooth tubing and perhaps shielding the stock intake airbox intake from engine bay heat will show at least as much gain as any open element intake.
Old Jun 25, 2009 | 11:36 AM
RickAKATed10's Avatar
That isn't mine. It's just a reference pic I found online.
Old Jun 25, 2009 | 06:19 PM
Pauls325's Avatar
i have a k and n cone directly on my MAF no problems yet i know they say how you should have straight tubing to the MAF but look where it hooks up on the stock airbox there is no constant dia. tube to it there as far as filter oil im just cleaning the sensor every couple weeks
Old Jun 25, 2009 | 07:59 PM
Mgpeagle's Avatar
I went with this one. Works awesome!
http://intense-racing.com/Merchant2/...=LSx_Induction
-Mike
Old Jun 25, 2009 | 10:48 PM
AlabamaGuy's Avatar
-Mike
Do you have to cut a hole in the fenderwell for this?
Old Jun 26, 2009 | 11:55 AM
Mgpeagle's Avatar
Nope. There is already a nice size hole there when the stock top half of the airbox is removed. Not sure about Monte's, Impala's, or LaCorsse's though. I can only tell you bout the GXP's because I have one.
-Mike
Old Jun 26, 2009 | 12:40 PM
Panther427's Avatar
This is my intake option
Attached Thumbnails Alternative intake setup?-s7300991.jpg   Alternative intake setup?-s7300959.jpg
Old Jun 26, 2009 | 01:31 PM
06MonteSS's Avatar
LS1Tech Sponsor
-Mike
nope, the Monte's and Impala's do not have that opening... would have to cut a hole in ours...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old Jun 26, 2009 | 02:25 PM
otherwisebusy's Avatar
YOU made this (PIC #1)? Looks sweet! How about a write up?
Old Jun 26, 2009 | 03:49 PM
Panther427's Avatar
I did make a big post long time ago. When i built it. Gonna change a few things around. When i get a chance i can look for it. Other wise just search the forum. And it cost about 45 $
Old Jun 27, 2009 | 02:56 PM
  #32
Pauls325's Avatar
panther is that pvc?
Old Jun 29, 2009 | 03:09 PM
  #33
heavyft's Avatar
Panther. Get a 45* rubber sewer coupler and replace that accordion!
I built the same thing for my 2002 GTP but made it a fenderwell intake.
