Homemade Headers
Old Jun 26, 2009 | 12:49 PM
ttranssam's Avatar
naw.....screw them f-bodys...i think a ls4 with just a good set of shorty headers and half way decent intake would be a damn nice gain and with a speced out cam you guys could have them little buggers throwing down 360+ if only anyone with one was close and had maybe 300 to throw into some gettho r@d i bet i can mak a sweet *** set of shorty headers that put out. **** + some texas speed 5.3 2.5s on them bitchez would be sweet too....
Old Jun 26, 2009 | 01:30 PM
Pauls325's Avatar
i think the way to make power on these get some heads that have the intake bolt pattern that the g8 gt has and get one of those manifolds...
as far as making things, this winter ill be working on making a bigger crossover and see if that helps anything im jobless right now though so i dont have any extra money for parts
Old Jun 26, 2009 | 02:17 PM
neilownz's Avatar
I have the tsp heads on mine. Should have done more while it was ripped apart like a cam though. So sad.
Old Jun 26, 2009 | 03:54 PM
Panther427's Avatar
ya we good decent factory 243 heads. But Damn them texas speed 2.5 heads have been rocking the local f-body guys. most them are like 420-450 with a simple H/C and Fast inatake. then over 500 with some N20
Old Jun 26, 2009 | 09:04 PM
TheMonteMan's Avatar
is the major issue with the intake manifold that people want to run dod with it?
Old Jun 26, 2009 | 09:13 PM
neilownz's Avatar
No it's because they designed it with the oil pressure sender in an unfortunate/restricting location to save money and not have to engineer a whole new block since that is the standard location for ls1/2 etc engine blocks...
Another possibility would be to use a larger downpipe than 3 inches or dual 2.25s that y back together later on or something.
Old Jun 26, 2009 | 10:08 PM
Panther427's Avatar
Should be able to mount the Oil preasor sensor of the side of the block by the Filter.
Old Jun 26, 2009 | 10:11 PM
MCSS07's Avatar
What about calling S&S or someone small and see if they would fab up a set? Or what about getting TOG's or SLP's for the 3800's and mod'ing them?
Just a few ideas.
Old Jun 26, 2009 | 10:42 PM
AlabamaGuy's Avatar
Just a few ideas.
You could probably use a set of 3.8L headers as a guide since they have to clear the same subframe and whatnot.
Also like the idea of mounting the pressure sender down by the filter...this guy may be on to something.
Old Jun 26, 2009 | 10:51 PM
MCSS07's Avatar
The only issue is the cars that had the 3.8 L67/L32's had more room in the engine bay than we do. Your right about using them as a guide and having the cross over pipe connect into the down pipe. This would allow the transfer of exhaust to more faster and open up the LS4 for better performance.
Old Jun 26, 2009 | 11:04 PM
AlabamaGuy's Avatar
From what I'm reading, the two major issues with LS4 performance is intake and headers. Now, we have good heads and a decent cam...honestly, if the engine won't flow to it's maximum potential with the stock cam, there's no reason to upgrade until these two items are taken care of. Now, the LS6 manifold thread seems to have died for the time being, but from what I read the main problem was the oil pressure sender, am I right? What else was a big deal? TB mounting?
Old Jun 26, 2009 | 11:09 PM
  #32
Panther427's Avatar
the electrical connector for the DOD, Mounting up the sensor locations, fuel rail issues.
Old Jun 26, 2009 | 11:20 PM
  #33
AlabamaGuy's Avatar
What kind of fuel rail problems?
Old Jun 26, 2009 | 11:34 PM
  #34
Panther427's Avatar
Tired mentioned it on his right up. im assuming the LS6 intakes bulges are bigger placing the fuel rail off center.
Old Jun 26, 2009 | 11:42 PM
  #35
williamGT's Avatar
Time they make the headers, our cars will be in the junk yard.
Old Jun 27, 2009 | 08:29 AM
  #36
MCSS07's Avatar
Sorry, but you can have the best cam and heads in the world, but if the intake/exhaust manifolds are as restrictive as the ones we have now then by opening them up ( headers or even ported ) you will allow better air flow which in return will allow more HP due to the bottle neck of the exhaust problem we have now.
GM put a ******* V8 in with a V6 thinking exhaust. Not the best thing in the world.
Old Jun 27, 2009 | 08:41 AM
  #37
AlabamaGuy's Avatar
What do you think I just said? That was the entire point of my post re-worded. Our two limitations are intake and exhaust. without one the other won't help out nearly as much.
Old Jun 27, 2009 | 08:43 AM
  #38
MCSS07's Avatar
Just making sure you understood what I was talking about
Old Jun 27, 2009 | 01:52 PM
  #39
Sittingmongoose's Avatar
The only problem i have with all of this is that i ported everything out, did a new exhaust and cold air and only saw a gain of about 20hp. So i am thinking if we did manage to created headers and or intake manifolds, we would not gain much. MAYBE 15hp if we did both
Old Jun 27, 2009 | 07:07 PM
  #40
idk about 15hp didnt the ls1 cars gain a decent amount with the ls6 intake? and the ls1 intake is def an improvement over what we have goin on over here.
