Hogan DP
Old Jul 5, 2009 | 06:56 PM
AlabamaGuy's Avatar
Default Hogan DP
Does the Hogan DP use the factory converter, or is it eliminated? Can you weld in an aftermarket converter in its place if you were so inclined?
Old Jul 5, 2009 | 08:11 PM
Mgpeagle's Avatar
You can get those with 3 different options. 1. Just the Dp that welds into your stock cat. 2. A catted version with a Magnaflow HF cat. or 3. Dp with cat delete. Option 2 and 3 will still bolt up to the factory or custom catback. I loke option #3 the best. I have that one.
-Mike
Old Jul 5, 2009 | 08:21 PM
neilownz's Avatar
I'm not sure he sells those anymore since the epa was up his *** about the catless dp... I think it's like hoganperformance.com
Old Jul 5, 2009 | 08:33 PM
AlabamaGuy's Avatar
The site doesn't show your 3rd option. I'm thinking I can get an aftermarket converter and the DP installed for cheaper than the bolt on one.
Old Jul 5, 2009 | 08:38 PM
neilownz's Avatar
Yea I'm pretty sure you can get the weld on version of the first part that bolts from the manifold with a flex section, then go from there.
http://hoganperformance.com/DP5S.htm
Old Jul 5, 2009 | 09:01 PM
AlabamaGuy's Avatar
That's the one I was looking at.
Anyone know the dimensions of our stock cat? Would it be easier to reduce the 3" pipe to fit a 2.25" cat or do a 3" cat reduced into the 2.25" pipe?
Old Jul 6, 2009 | 12:38 AM
Nacho SS's Avatar
I have full Catless DP for sale, bolt flange to bolt flange, 3" from Hogan with flex coupler...PM me if you want it.
Old Jul 6, 2009 | 06:00 AM
98GTcoupe's Avatar
Why does the Hogan DP only say it fits 05-06 GP GXP/Montes/Implys? Why wouldnt it work on 07-08 GXP? Same damn thing right?
Old Jul 6, 2009 | 06:04 AM
neilownz's Avatar
Yes it will work
