CAM trigger wheel cam sensor?
2005 to 2006 LS4 is a 1x wheel
2007 on up is it a 1x or a 4x wheel for the CAM/cam sensor?
Crank went from 24x to 58x in 2007 on up. For anyone replacing an engine, make sure you stick to the year of your vehicle when replacing engine due to the differences in sensors and ECM's. 2005-2006 use 05 or 06 motor. 2007 on up, use 2007 on up motor.
Thanks,
As far as I know none of the 58x sensors E67 comp system are compatible with the E40 system 32bit digital verses 16 bit.
You even have to change the intake manifold and MAP!
