Magnaflow Resonator
Old Oct 1, 2009 | 04:54 PM
rlfgx2's Avatar
Default Magnaflow Resonator
For those of you with the full magnaflow system, anyone know the part number for just the resonator? I have a shop that will do a custom install. I'm going to go with 2 mufflers, tips, and a resonator. I have the part numbers for everything but the resonator. I can purchase the components cheaper elsewhere and they'll be willing to do all the tubing/pipes. I think I can get parts and labor going this route cheaper than buying the whole kit for $700.
thanks,
Old Oct 1, 2009 | 06:24 PM
JP_GXP's Avatar
I have one that has never been used sitting in storage still wrapped up.
EDIT: BTW, I got the whole kit for $517.
Old Oct 1, 2009 | 06:55 PM
BuickRacer's Avatar
Too bad you aren't in CA, I would give you mine just to get it out of my garage. Honestly, it's a 1-2 HP difference without it but the sound difference is there once the rear muffler packing has worn a bit.
Old Oct 7, 2009 | 11:25 PM
CooterXJ's Avatar
How much did the straight pipe to replace the magnaflow res. cost you? I want to ditch mine for the sound
Old Oct 7, 2009 | 11:35 PM
DP 08 GXP's Avatar
mine to get removed and replaced with pipe was $50
Old Oct 7, 2009 | 11:38 PM
CooterXJ's Avatar
Did they use stainless steel like the rest of the exhaust or cheap aluminized steal? did they weld it in or put a flange on it to bolt in (incase ya ever want to put the res. back in).
Old Oct 8, 2009 | 12:17 AM
DP 08 GXP's Avatar
it was a stainless pipe that was welded on.
Old Oct 8, 2009 | 10:51 AM
JP_GXP's Avatar
They charged me $10 for welding the pipe and flange. I just brought the resonator to them they measured it, cut the pipe to length and found a flange that matched. I installed it myself with the rest of the catback.
Old Oct 8, 2009 | 11:02 AM
CooterXJ's Avatar
got a pic?
Old Oct 8, 2009 | 04:41 PM
JP_GXP's Avatar
Just took 'em
straight pipe
with MF res
with cat
The flanges were a little off and there was a slight leak...
And my filthy cutout, that apparently needs to be rewired a little...
Old Oct 10, 2009 | 04:04 PM
1 CLEAN SUP3R SPORT's Avatar
i paid $25 to be replace by straight pipe
