V8 Fiero with an LS4
One thing that bugs me is that I used the stock Monte fuel sending unit in the Fiero tank. The Fiero tank only holds 11gal. I don't know what the monte can hold, but the difference in size really screws up the D.I.C. miles remaining estimate. It is nearly half what I can actually go. It starts off over 400 miles but I can only get 200-250 depending on how heavy my foot gets.
It sure would be nice if I could recalibrate that?
I have to have a light foot on corners from a dead stop. The 255 45 17's brake loose easily and has a bit of snap steer at throttle lift. The balance of steering with the throttle and steering wheel is a trick, at the limit.
It's been a while since I checked out the thread over on PFF so I don't recall if he upgraded bushings/struts... Fiero's essentially have a FWD set-up in the rear, so torque steer could still be an issue.
The quad cam 3.5 Short Star was rated at 215hp and I did not have any of the snap steer. I now have about 100 extra hp over that swap and I think the bushings just cant take it. The car rides beautifully and very quiet so the rubber would have been fine for a while longer if I did not swapped in this V8. Looks like I will just do polly in the rear and see what happens. I want to keep the rubber in front because I like the smooth ride, so I will replace it with new. My opinion is that the front of an 88 does not "need" polly like the other Fiero's to handle better. The rubber just needs to be in good shape and it will handle great. The rear is a little different. It has more bushings than the front and with the 300+hp can get more "twisted", so polly should help.
I appreciate custom cars because I know how much blood sweat and tears go into them. So talking to people about the car is making all the work worth while.
At the Coast on highway 1 I noticed several people stopped and looking at the car. One person was taking pictures of it so I opened the deck lid for him. 20 min latter I went back into the restaurant to eat. Then after breakfast more people were looking at it. So I must have talked for 45-an hour about hot rods.
I get to hear about lots of cool stuff and show off my car at the same time. Infact today I was a little late to work because I was stopped by a guy in the parking lot who was asking questions about the car.
I want to get a tune done on it so my question is what are the most common things changed on a "high performance" daily driver.
The stock tranny shifts so unbelievably smooth in this car that I literally cant feel it shift sometimes. So I know I want to install a shift kit. The car is lighter than the 06 Monte that the engine came from so I am not concerned about hurting the tranny. I just don't want the extra hard shift setting when I install the kit. Other than the none stock air box and "free flowing" exhaust the drive train is stock. I have no muffler, just a cat and resonator tips and it does not have the typical code like the catless down pipes are getting.
Any and all advice is greatly appreciated.
I'm not suggesting that you go all the way to max pressure, but if you ever want to find out what max pressure shifts feel like, unplug the maf and go for a short drive. For whatever reason, GM programmed the transmission to provide max pressure when a MAF failed - probably to ensure people brought the vehicle in for servicing. The downshifts are brutal.
Sounds like you've done relatively few mods, so your tuning requirements aren't too extensive, with your intake and exhaust mods, you probably need to have the VE table and maf curve tuned.
Stock tune delays entry into PE mode, have it come in around 2500. The PE fueling table is **** - as in ridiculously rich at higher rpm, you probably want to set the PE AFR to ~12.8 across the board. this will help power in the upper rpm range. PE enrichment rate should be increased to 1 from .02 - all this does is decrease the time it takes to move to your desired PE AFR
If you've upgraded valve springs, consider increasing shift points and rev limiter - has a benefit in first gear acceleration.
I removed all engine torque management and about half of the transmission torque management
The engine can take a bit more timing in the higher RPM and "dyn cyl air" cells, no real point in bumping timing below 2000 RPM, I just got knock when I tried.
There's a few other things that might be adjusted, but this is most of the basics.
The torque management tuning won't fix your problem when accelerating around a corner, the only way to avoid this is to disable differential score protection. Problem is that that puts the differential clutches at risk. Since you are rear wheel drive, you might get away with it. I think Ryan did this on BLKCOFY's LS4 swap.
[YOUTUBE]http://www.youtube.com/watch?v=OE-VqF94wBQ[/YOUTUBE]
[YOUTUBE]http://www.youtube.com/watch?v=epoLQQU73i0[/YOUTUBE]
Thanks, the car is far from complete but I will continue to work on it till some one makes a good enough offer or till I just get another car to build.
I would love to have a Saturn Sky or Pontiac Solstice to swap V8 into.
