GXP fuel mileage ??
I tried running 93 in my car for two weeks and the mileage got worse and there was no performance increase. The LS4s have a problem with high IATs due to the bad MAF location and exhaust crossover. High IATs retard timing. 93 octane is suggested for vehicles with high compression/advanced timing. Unless you lower your IATs, 93 in your STOCK LS4 wont do anything for you.
I would like to see some documentation to back up this rumor. Thanks!
I'll admit I am wrong this time. I don't have an owners manual for my car because I bought it used. It took searching in the Service Information Owners Manual section to come up with a black & white answer. Document #1570979 reads:
Why does the truck engine which makes similar power run happily on regular fuel??? WTF! They couldn't make the LS4 same way?
My father works in a Sonoco refinery and they test the differences between grades of gases. The higher octane CAN improve performance if your car is TUNED for it. BUT you WILL get better gas milage on 87. This is because the 93 burns so quickly that it isnt possible for your car to burn all of it before it exits your cylinders. 87 makes better use of all your gas. under most circumstances that is.
And since i did my cam, got rid of DOD and did my intake, i average about 19mpg on the highway and have to fill up everyday. I used to get 35-40mpg on the highway and fill up once a week.
Shell
BP (Amaco)
Mobil
Speedway
Citgo
Marathon
7 Eleven
I only am playing around with mixing in 87 octane because of the below freezing temps and the volatility of 87 vs 93 in the weather. I think the volatility of 93 is too low to run in these temperatures. Plus I'm not worried about detonation or spark knock because there is snow on the ground, where am i gonna go?
In the summertime I'll run straight 93 and enjoy my power then. My father works in a Sonoco refinery and they test the differences between grades of gases. The higher octane CAN improve performance if your car is TUNED for it. BUT you WILL get better gas milage on 87. This is because the 93 burns so quickly that it isnt possible for your car to burn all of it before it exits your cylinders. 87 makes better use of all your gas. under most circumstances that is.
