Am I The First Here?...
Old Nov 30, 2009 | 12:24 AM
dewd87's Avatar
I'm at 134,500 miles and just changed out the original plugs and wires.
Old Nov 30, 2009 | 04:04 PM
Tap Dat SS's Avatar
Originally Posted by hurley_21_07
Correct! It went at about 80k.
Everything is original and it perfect working order other than new michelin tires, e3 plugs, and K&N air filter. Oh wait, sorry, the two little lights that light up my two front window switches are out. LOL Hardly noticeable.
I wish I could figure out why it has a rough idle sometimes, but once I get going it's perfect. I think it may need a SeaFoam treatment. Cleaned the MAF and TB to no avail.
E3 plugs = FAIL! Put Delco platinums back in and I bet your idle issue goes away. AC Delco, not autolight, not champion, not bosch. GM's hate anything but Delco platinums.
Old Nov 30, 2009 | 11:24 PM
hurley_21_07's Avatar
It did this before the plugs.
Old Nov 30, 2009 | 11:47 PM
3.8redbird's Avatar
my gen 1 sbc idles rough to. damn those cams
Old Dec 1, 2009 | 08:55 AM
Tap Dat SS's Avatar
Correct, what I am saying is there is a possibility, at your mileage, you had a plug or two that may have been carbon tracked and caused the idle condition. You did install new plugs which would normally correct the concern but, again, because they are not Delco platinums, may be causing the same issue. I rarely see light idle misfires on coil on plug that isn't caused by a spark plug issue.
Old Dec 1, 2009 | 12:43 PM
Hmm. I really hate to change out 5.99 plugs
Old Dec 1, 2009 | 01:23 PM
DP 08 GXP's Avatar
i have autolites and my car runs just fine
Old Dec 1, 2009 | 02:29 PM
Tap Dat SS's Avatar
Yes... but I think the AcDelco platinums are at least that... they may be over 6 bux now too!
Old Dec 1, 2009 | 02:38 PM
3.8redbird's Avatar
I run NGK
never had a problem on any of my cars
and i run 6s usually for the laughing gas
