Spare Tire for '08 GXP ??
Old Dec 8, 2009 | 07:08 PM
2000blkta's Avatar
Default Spare Tire for '08 GXP ??
I put a set of Blizzaks on '04 Comp-G wheels on the wife's '08 GXP. I found a jack with the foam insert, etc now I need a spare tire. Will I need a 16" or 17" compact spare? I was looking around eBay but wasn't sure what I needed as IF the GXP would have come with a spare. Would the 17" compact spare fit in the spare tire well in the trunk? One of you guys has probably figured all this out already. Thanks
Old Dec 8, 2009 | 07:15 PM
williamGT's Avatar
people has been using the Bonneville GXP spare tire.
Old Dec 8, 2009 | 07:22 PM
2000blkta's Avatar
do you know size that is ? I want ot make sure not only does it fit front or rear but also clears the calipers.
Old Dec 8, 2009 | 07:39 PM
williamGT's Avatar
I'm not sure, but I think someone will jump in.
Old Dec 8, 2009 | 07:59 PM
JC05GXP's Avatar
The one I have is from a Caddy DTS 05 and up (same as the bonnie rim). Its 17x4 and IIRC the tire is 125/70/17.
Old Dec 8, 2009 | 09:46 PM
JP_GXP's Avatar
No 16" rim will fit the GXP, best bet would be to find another Comp rim, because I'm unsure as to whether a compact 17" will fit either, the only downfall of larger rotors.
I recently acquired a rear GXP rim that will be my spare. I plan on it just chillin' in my trunk, doubt it'll fit in the hole that they so lovingly teased us with.
Old Dec 8, 2009 | 09:50 PM
EmersonHart13's Avatar
You need the DTS or Bonneville GXP rim stated above.
Full details on Clubgp.com
Old Dec 8, 2009 | 11:13 PM
Red03GT's Avatar
The 16" that comes in V6 W-bodies may fit the rear....maybe. I got a flat on my right rear on the GXP a couple weeks back. Once I got the car home I threw it on just to see if it would clear the calipers and theres about a hair width if I remember between the caliper and the valve stem. I wasn't going to drive it to the shop like that but I goofed and totally forgot and drove it...it made it but it was only a short distance. So there is NO way of course it would clear the front calipers.
Old Dec 9, 2009 | 12:46 AM
Neanderthal's Avatar
Spare from LaCrosse Super should fit, its front brakes are the same size as the GXP. I think Impala and MC SS also have donuts, they should be the same size.
Old Dec 9, 2009 | 03:06 AM
JP_GXP's Avatar
I thought all LS4 Ws came with a compressor and sealant?
Old Dec 9, 2009 | 06:36 AM
Panther427's Avatar
no just GXP because of the Mis-matched front and rear wheel widths
Old Dec 9, 2009 | 07:46 AM
2000blkta's Avatar
Ok, so it sounds like if I find a compact 17" spare from a Monte Carlo SS it would fit ?
Old Dec 9, 2009 | 08:07 PM
2000blkta's Avatar
I haven't been able to confirm the Impala spare will clear the front calipers though I did find somewhere that a Bonneville GXP or Cadiallac DTS spare might fit. They are both sort of a 5 spoke design in black. Anyone know anything ?
Old Dec 9, 2009 | 10:52 PM
Maybe it'll go in sideways.
Try Detroit wheel. www.detroitwheelandtire.com
Old Dec 12, 2009 | 02:08 PM
Maybe...
Solution for GXP spare http://www.clubgp.com/newforum/tm.asp?m=4007587
Look at how tight that is over the brakes...
Old Dec 12, 2009 | 02:39 PM
YngBird's Avatar
I still can't believe you drove it there. Savage
