lowering
Old Dec 20, 2009 | 07:35 PM
bigalnash's Avatar
Default lowering
i was just curious to see if you guys are that lowered with the ssc springs actually noticed any improvement in the handling ? also shouldnt be the shocks and struts be upgraded? i have the bilstein struts on my gxp so i dont know if those can handle the ride on the drop or not..
Old Dec 20, 2009 | 08:51 PM
Nacho SS's Avatar
Big time. The car handles like a totally different animal with the SSC's, KYB struts, and the DR STBs.
Old Dec 20, 2009 | 10:19 PM
mike690003's Avatar
I'm lowered in the front only, due to a sound system in the rear. It seems to handle a little more tightly, but it LOOKS SO MUCH BETTER!
Old Dec 21, 2009 | 06:25 AM
bdyman's Avatar
the dudes screen name slips my mind right now, but i know hes in peoria,il and has a gxp lowered on the ssc springs, hopefully he will chime in for some info for ya
i hate my car but im going to lower it this spring, it is a must
Old Dec 21, 2009 | 08:32 AM
98GTcoupe's Avatar
I know that there is a few fellas on ClubGP lowered on the stock GXP struts with SSC's and Ive only heard nothing but good from them. I plan on lowering my this spring on SSC's with the stock bilsteins, they are a great performance strut, some would say the best you could get but IDK i think maybe the AGX's are....
Greg
Old Dec 21, 2009 | 09:58 AM
DP 08 GXP's Avatar
Greg
i have the same exact plans.
Old Dec 21, 2009 | 10:47 AM
RickAKATed10's Avatar
I'd love this setup. Maybe some day!
Old Dec 21, 2009 | 01:20 PM
Nacho SS's Avatar
It's probably my favorite mod(s). It took all the body roll and that questionable feeling when cornering out of the car. The handling is a lot more linear and the car feels planted and nimble. I impress people when I can hold canyon sweepers at 90+ in a boat of a car.
Not to mention the car rides somewhat close to stock and looks sick.
Old Dec 21, 2009 | 01:26 PM
ImpSS07's Avatar
Which KYB's do you have??
Old Dec 21, 2009 | 01:56 PM
Nacho SS's Avatar
http://app.infopia.com/Shop/Control/...721/rid/127794
Old Dec 21, 2009 | 02:01 PM
What number do your ride on? I heard if you leave it on 2, then you could basically get the GR2's and have the same ride.
I had Eibach springs and AGX's on my Stratus coupe and it was a rough ride, but I only got the AGX's because I found them for the same price as GR2's. Even though it was a rough ride, the car rode like it was on rails.
Thanks.
Old Dec 21, 2009 | 02:16 PM
keviiinn's Avatar
I've always wondered, how do you adjust the stiffness of these struts? is it easy to adjust them or do you need to take off the wheels?
Old Dec 21, 2009 | 02:37 PM
Nacho SS's Avatar
Thanks.
I have them set firmer than the #2 setting and it took a little bit of getting used to before I liked them. The GR2s aren't adjustable and aren't nearly as aggressive as the AGXs.
Yes, you take the the wheel off and adjust the screw valve with a screwdriver or there's an adjustable **** on the side that dictates firmness.
Old Dec 21, 2009 | 08:09 PM
bdyman's Avatar
Thanks.
dude i see you around all the time, come spring time i hold meets the more the merrier i say
Old Dec 23, 2009 | 12:27 PM
bigalnash's Avatar
i still wonder tho if the bliesteins can handle that kinda height ...
Old Dec 23, 2009 | 01:38 PM
Nacho SS's Avatar
For a little while, yes they can. But when you lower a car, you put an increased load on the shock/strut to dampen the movements in a shorter stroke and with more frequency, so that tends to kill stock struts quickly.
Old Dec 23, 2009 | 09:29 PM
imnmbr1's Avatar
Where do you get the ssc springs?
Old Dec 23, 2009 | 09:42 PM
mike690003's Avatar
Give em a look :http://www.superiorsportchassis.com/
Call Fax or email:
Phone:
Fax:
E-mail: 604 591-9898
604 591-9896
sales@superiorsportchassis.com
Old Dec 26, 2009 | 07:03 AM
bigalnash's Avatar
hmm so should i replace them with new bliesteins or should get kyb struts like yours? would those work on the gxp kyb any better?
Old Dec 26, 2009 | 01:08 PM
Nacho SS's Avatar
With an adjustable, you have better control and valving options on a lowered car because the shock/strut can be tailored to work better with a shortened stroke and moving with greater frequency.
If you replace the Bilsteins, they have about a 10k-15k life now with a lowered car.
