Cai dimentions
as of right now im addressing two problems with the new intake
problems
1. the heat soak experienced by the MAF
2. the inadequate filter area with the stock airbox
in addition i am concerning myself with reducing turbulence into the MAF because i believe it has a huge impact on these cars
also
im planning on this system to use a panel filter for a straighter shot into the intake (for those with removed or ported headlights) any other ideas would be awesome you should be seeing renderings of it sometime before the tenth of jan
thanks,
Paul
I were to do it over again I would be inclined to get one of those true fenderwell intakes (the ones that require the fender brace to be removed), and run the FWI intake tube through a "surgically altered by Dremel" stock airbox to cover it all up.
