D-I-Y shift kit observations
Old Jan 10, 2010 | 03:38 PM
BuickRacer's Avatar
Default D-I-Y shift kit observations
Yesterday I installed a D-I-Y shift kit and I wanted to post my observations.
I used 1" and 3/4" shims from the hardware store and replaced the stock 1-2 accumulator spring with a 2-3 spring (P/N 23203977) which is a much thicker coil. The car will now lightly bark the tires on the 1-2 at WOT and the 2-3 is mmm-okay; however, if & when I take the pan down again I will shim up the 2-3 accumulator spring 1/4" to see if I can get a little more pop on the 2-3. At light throttle the 1-2 is enough to let you know "hey, I'm happening now" but not outrageous.
Frankly, I think anyone looking to go the shift kit route will find the 1" & 3/4" shims to be just fine. Anyway, I hope this helps someone!
Old Jan 10, 2010 | 03:49 PM
Sittingmongoose's Avatar
it acually chirps when it shifts? wow i cant even come close to getting mine to do that and i make a lot more power.
Old Jan 10, 2010 | 04:12 PM
BuickRacer's Avatar
Yes, at WOT. I have the line pressure upped a bit in the tune as well. My fear was that I would get a "dashboard in my lap" slam on the 1-2 but it has worked out okay.
Old Jan 10, 2010 | 04:54 PM
94ss06gxp's Avatar
thanks for the info
Old Jan 11, 2010 | 09:19 AM
blakss's Avatar
waiting to install the same shift kit just been way to cold out here but good to hear u like it
Old Jan 11, 2010 | 02:58 PM
Compg's Avatar
I had the same thing done on my GTP Comp G when I had it. DIY shift kit and line pressure increased. Loved it, until on the 1-2 shift I snapped the input shaft that grenaded my TC which in turn sent pieces into the rest of the tranny. $3200 later I had a race built tranny and was good to go.
Moral of the story is I wouldn't recommend both shims/spring DIY kit "and" increased line pressure to long on the 4t65e-HD, because we all know it's not HD.
Tate
Old Jan 12, 2010 | 08:44 PM
nmp0098's Avatar
HD only refers to the differential, everything else is the same mechanically. Otherwise, it's the TCM that keeps the trans alive (stock engine) with aggressive torque management.
