Impala Console Removal
I know I'm probly overlooking something really stupid, got the 2 bolts out of where the console attaches to the shifter plate and the 2 screws out of the back by the seats. What am I missing here? Thanks a bunch guys! Front floor console replacement (Impala) 2-76
Preliminary procedures:
1. Remove the front floor console bin liner.
2. Remove the console shift lever bezel. Refer to Console shift lever bezel replacement on page 2-75.
Tip:
Use only a plastic trim tool to lift the shift lever bezel from the console. Do not use any tool between the trim bezel and the shifter.
Apply the park brake and shift lever rearward. The sound deadener must be reinstalled if the wire harness is removed or replaced.
1. Front floor console bolts (qty 6) Tighten 7 Nm (62 lb in)
Four are in the the console area that is covered with the door and two look to be alongside the shifter.
2. Disconnect the electrical connector.
I know I'm probly overlooking something really stupid, got the 2 bolts out of where the console attaches to the shifter plate and the 2 screws out of the back by the seats. What am I missing here? Thanks a bunch guys!thks
toolbox1
